Results 1 to 2 of 2
    May 2008
    Default dm 600, just red light on power up.
    well i had the 600 working on cli image and wanted to try a different one ,dreamup would not flash. [useing laptop / vista and comport converter ] so i thaught i,d do it as suggested elsewhere with telenet. ie
    mount -o remount,rw /boot
    rm -f /boot/*
    reboot
    used putty program to do this. i had ip set on the box and i could telenet to the box before this. after putting in the command mount -o remount,rw /boot
    rm -f /boot/*
    reboot the box went off and came on with red light flashinrg and the odd green flashing light every now and again. now i.m stuck,any idea,s m8? thanks for the reply.also tried restarting the box with power button held down , still no joy.?
    __________________
    Africa-Kenya-Nbi
    For your flashing use the serial cable and try again and again
