Results 1 to 6 of 6
    malaysia
    Default Actuator arm problem
    Hello everyone
    Got a small problem on my sat arm , it been on the sat for 3 years no problem, nowdays when i am on Pas 7/10 and then move it back to AS3, i have to realigne the arm, i am using a stand alone superjack positioner to my 18inch arm, anyone got a clue how to fix this problem.
    rdg
    R-D-I SPONSOR Mentor
    Thailand
    Quote Originally Posted by amrit View Post
    Hello everyone
    rdg
    The Problem is cos yr actuator is old and worn that once yr dish sets at 68.5 east the weight of yr dish sets the limit past 68.5 east .
    You can try and move and adjust the ARM on the mounting bracket so it does not go past 68.5 east or take the cover off the bottom of the actuator there is a adjuster screw in the middle
    canine consultant Expert
    Buy a longer actuator, unfortunately you don't say how big the dish is, but when your moving a dish up from a low angle a tremendous amount of torque is employed to raise the dish. And a actuator of that size would only be be for small dishes of 1.5 meteres at best. In some cases where the actuator is positioned incorrectly, or is of insufficient size, the arm [ram] will tend to push the dish down, with disastrous consequences
    regards from OZ bassett
    Jul 2006
    thailand
    easy to fix take your arm off the dish then holding both ends of the arm move inout you will be able to feel play up and down so you need to put a washer in it to do this you need to take the black cover off to to get to the cog wheels you will see a circlip take that off and put a metal washer on the other side but the best thing is a plastic washer this will take up the slack in the arm the tighter the fit of the washer the better it is
    Quote Originally Posted by big pimpin View Post
    good info big,,,commonly refered to as "shimming".
    cheers,,,dave
    malaysia
    Tks guys.
    My Dish size is 6 ft bassett, will try out all the stuff you guys posted.
    Tks again
    rdg
