Thread: LNB problem
    Jun 2007
    Default LNB problem
    I had a problem with my KU band LNB few days ago. It did not pick signal from TP's where the frequency is bellow 12000.
    I posted this problem here in the forum & as per the information reveived, I have changed the LNB. The new one worked perfectly for about a week & again the same problem came. Now the new LNB also don't pick signal from TP's of freq below 12000. I have checked this with DM500S & DM600 PVR & both have same result.
    Can someone please help me to resolve this problem?
    something must be causing your lnb to die. check your config from the receivers to match that of your lnbs (High-Low freqs), or your cables are shorted in some way.
    pakistan
    i also have the same problem i have skystar2 card.but thanx to sir boknoy for useful information i will check my cables i have two card installed on two cpu.i think problem is in cables.
    Pakistan
    i have same problem like this in my HUMAX 5400z Plus receiver,wich not tuned any channel that have symbol rate less then 3000.plese help me.Thanks
    canine consultant Expert
    anything below 12000 requires a Universial LNB.
    But why do people persist on posting this sort of question, total devoid of information.
    Try posting the satellite your trying to access, and the complete frequance, then others can check it for you, and report back. For all we know there could be some data changes, that prevent it playing.
    regards from OZ bassett
    Quote Originally Posted by KAZIM ALI View Post
    I think you mean 30.000
    Pakistan
    channel like waqat tv H-4003,s/r:2965 on pas7/10 and AAj tv V-3750,s/r:2821 on asiasat 3s and many other channel thats symbol rate less then 3000.I buy this recevier from Saudi Arabia now i am in pakistan.i also same problem in saudi arabia.other reciver working normal.
