Results 1 to 9 of 9
    May 2008
    Default help in connecting DB using DCC
    good day to all!
    I am newbie on this stb (DB), I am trying to connect my stb and pc using DCC with switch/hub. when i connect it say "ERROR 10057 in function Send Socket is not connected"
    please help
    thanks in advance
    May 2008
    when i try to open it using http and assigned ip address it will open and working
    please help
    what type of connection are u using?,,lan or null modem cable?make sure u have selected the correct one in the program setup prefs.
    cheers,,,dave
    May 2008
    thanks Mr. Dave
    I am using LAN connection
    Quote Originally Posted by dandy_r View Post
    thanks Mr. Dave
    in connection type,,,what do u have selected?,,,and make sure u have correct username password.
    maybe what u r calling a hub is a router,,,try with both connection types.
    cheers,,,dave
    May 2008
    I used switch and using root as username and dreambox as password
    i will try again thses to connection
    have u connected to ur box with this program b4?,,,im wondering if it is ur computer firewall stopping it.try temporarily disabling ur firewall.
    cheers,,,dave
    May 2008
    Thank you very much Mr. Dave
    It is working now i disable my firewall
    u r welcome mr dandy,,,,,have fun in there,,,but dont forget to restart ur firewall and make the correct permissions for that program .
    u should also change the password to something different to default.
    cheers,,,dave
