    May 2004
    Myanmar
    Default NewB 630 Receiver Help Need !
    Hi Bro,
    I am from Myanmar. I bought a new Sat Receiver NewB 630 that can watch HKC (13. Now I am facing a problem with that set-top box. The box shows blue test screen with 4 lines. Left Key - Enter FT1 application, Right Key - Enter FT2 application and shows version information. And it does not continue. How can I do to solve this problem? Thank you.
    21.95° N 97.06° E
    Quote Originally Posted by winthu View Post
    Hi Bro,
    Yes this is the new model of X-Sat 430 N2 and all X-Sat Series.For N2 , both X-Sat N2 and NewB 630 is not good to use bcoz. their flash is not flexible with N2 software.So u need to flash ur receiver with Mestroflash + N2 software.
    Sometimes , when u power off ur receiver then open it again the flash is gone again.Totally it's not good to use for N2.The best way is to take this N2 card and use in Innovia 3088 CA and NewStar.
    Thanks.
    " 李俊明 Born To Help People "
    May 2004
    Myanmar
    Thanks for your help, Ko Yan Naing. I'll try it.
    21.95° N 97.06° E
    No problem M8 . Good Luck.
    Regards.
