    88dBuV
    Default DM500 LNB problems
    Installed a Ku dish and for searching max signal connected the LNB with a dm500 receiver and spectrum analyzer.
    No noise so LNB didn't get any voltage from receiver, searched a bit in the settings but nothing. Receiver was setup before on another location and all was working fine there.
    Second DM500 receiver, same story, used now the transponder menu and select some other frequencies and bingo LNB came to live. Finished the Ku dish alignment and connected the receiver to a C band dish for Thaicom. Again no noise, selected another C band transponder freq. nothing, selected a Ku freq and had noise, switched back to the c band transponder freq. Aligned the C band dish for max signal but got no lock on any transponder, time was flying with this kind of 'fun' and was fed up with it , picked up an old dvb receiver and got immediately a lock and picture.
    Shall try later with different images to check what now exactly happens with LNB voltages after startup but I can't receive a thing on the C band with two dreamboxes with that LNB.
    Jed, KSA
    Dont waste your time on Dreambox 500 as I am still searching solution to all this problem.
    Africa-Kenya-Nbi
    Just do a proper set up to get the tunning correct on dreambox, at times it is a problem, but lots of patience and reading past set up problems will help you.
    make sure your lnb settings on dreambox are correct. if not go to individual settings and do it your ownway for the set ups.
    Jun 2005
    Australia
    And maybe try a reboot after changing settings before rescanning
