Results 1 to 6 of 6
    Ali4u
    Default Experts HELP ... HELP .. Required .. ?
    hi .. e.body
    hope to be fine and enjoying ur time !
    Experts Plz help me ... regarding recording ... I have my Reciever attached to my computer for diplay ... through Pixel View ... now my question is that ... what is the best way to record movies .. as when i record something thorugh my pixel view .. the file size is too big .. so what to do to keep the file size small ... Any Idea .?
    All suggestions welcomed ... n thanks in advance .
    @ali4u,
    since you are most probably recording on the mpeg2 format, it is but normal for you to have big file sizes for a movie, around 3 gigs per hour i think? the file size is determined by the lenght of your movie being captured and the bitrate you used on it. now, there are some calculators for that, like powerbit. then also, you should be able to customise your capture profiles basing on the bitrates you specify and from that, you can expect how big your mpeg2 file will be after recording. now, to shrink the mpeg2 file, you may convert that to other formats, like divx if you like. divx offers good compression with minimal distortions and loss in quality. i really doubt though if you can stream and convert at real time since that would take a lot of cpu power from your box.
    some guides for recording
    http://www.doom9.org/
    Ali4u
    @ali4u,
    I am recording with Pixel view .. the defualt format is "avi" .. and no other format supported ....and wheh i check the file size even 10 secnds recording for 36 MB ... any soulution to keep the file size minimum ..?
    if you cannot modify the default format and bitrate, then i dont know how you can modify the filesize while recording. after recording however, you can shrink the size of the file by converting it to other formats, then delete ur original avi file.
    Ali4u
    Default Thanks !
    Ok..dear ..thanks for your replies ...
    I will definately try to change the bitrate .. but i dont think if the picture quality will remain the same ...! ..lemme search for any other solution on NET ... thanks.
  1. Help required for posting
    By kachak in forum RDI - English
    Last Post: 3rd August 2006, 17:25
  2. Emergency Help Required
    By Mathila in forum RDI - English
    Last Post: 23rd July 2006, 22:42
  3. Experts Guidence required
    By shadowkhan in forum RDI - English
    Last Post: 16th June 2006, 12:49
  4. dish tv in dubai....help required frm experts....
    By dj mufty in forum RDI - English
    Last Post: 14th June 2006, 01:32
  5. CBN 45E CARD REQUIRED
    By zafarjoia in forum RDI - English
    Last Post: 14th March 2006, 22:32
