Results 1 to 11 of 11
    Default Connecting 2 receivers, Experts plz help
    i have hotbird, nilesat, intelsat and asiasat dishes installed.... currently i am using humax 5400z. Is it possible to use another receiver with my 2nd t.v. in other room?
    I think if i connect the lnb-out port from my hummy to the lnb-in port on the other receiver, it might work. can somebody confirm it.... and can i watch all channels this way? and is it harmful for the receivers to connect this way?
    thanks for any help
    use twin out lnbs, then connect all the output of the second lnb-out to a new disecq switch. then attach your 2nd receiver to the new disecq switch.
    The main reason is that I dont want to replace the existing lnb's and go through the headache of installing new diseq switches or wires. Thats the reason to ask if its possible to do it from receiver to receiver in my question above....
    Quote Originally Posted by superman001 View Post
    hi m8,,u can do as u suggest from one stb to another,,,but,,,u will only be able to view the lnb that is selected by the first stb,,and only in the same polarity (horizontal /vertical).
    cheers,,,dave
    Jun 2006
    Get a Multi switch, thats the best option if u dont want 2 go thru the replacing of the LNBs.
    check this post http://www.rdi-board.com/showthread....ht=multiswitch
    Regards
    Quote Originally Posted by satpal123 View Post
    Regards
    Although a good solution but isn't there anything simpler than that... bcz i want to use only 2 receivers and the multiswitch is for 12 receivers... the 2nd thing is also i have to check saudi arabian market to see if its available..
    Jun 2006
    Well u get multi switch for 2 recievers also i live in bahrain and i saw it here so it shud definetely be in Saudia also. It was Approx 9 Dinars here, 90 riyals saudia
    satpal ji, thx for ur help. God bless u..... i will try to look into the saudi market
    a multiswitch WILL require you to have twin out lnbs too. the SIMPLIEST, ECONOMICAL and SAFEST option was the one i described above. true, you can do loop-out connection from your receiver to the other but you RISK yourself of burning the tuners, disecqs and lnbs.
    it's your life..... it's your choice.
    yes, i was also afraid of burning those things...seems ur solution is the most feasable in the end.......thx and God bless u
    Apr 2006
    Is that true!, any thing like this burning happened before?
    I would like to do same installation for my 2nd room installation. Its really put me in worry!
    Thanks Bokonoy!
    Enjoy while FTA....................
