Results 1 to 2 of 2
    Apr 2004
    Germany
    Default Problem with Old Ird*to-2 Card from Pehla using CCCAM
    Hi Folks,
    i hope some guru here around can give me a helping hand regarding an Old Ird*to-2 Card
    I've a ADD-Pehla subscription and got the card in September 2003 and used it since in an Ird*to Module. It runs fine as loong as i use it in the Modul but once i use CCCAM 2.0.4 or even 2.0.8 no picture whatsoever.
    Strange that the card was well read by Gbox 2.1B and Gbox 2.25 and update regularly
    So it can't be any kind of fault in the card
    Anyone has a clue what i need to change the in cccam.cfg so the card is detected and read properly ?
    Thanx for any helpful advice
    in the cccam cfg file you need to have:
    CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
    CAMDATA: /dev/sci0 sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    TRY ALL CHIDS : /dev/sci0
    pay attention with sci0 or sci1 according to which internal card reader you are using.
