Results 1 to 3 of 3
    Jed, KSA
    Default How to put ART ST keys in Dreambox 500S?
    Can anyone guide on how to do it as I am not able to view using the one available.
    Jun 2006
    Quote Originally Posted by afridij View Post
    I have no idea abt the menus of Dreambox but it should have Tools>Key editor & then select Irdeto2 > ADD 060400 . Then enter the keys as posted in the correct index 06 or 08.
    Hope this helps
    Jun 2006
    Just use older version of MGCamd Emu as MGCamd 1.28 which is available from the update menue from your image
    then by any browsing software edit the softcam.key file in var/keys folder
    input the code that way:
    I 604 06 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    whatever it is 06 or 08
    but unfortunatly if ART and showtime both are using the same index 06 or 08 you have to choose only one of them
    then restart the emu and it's done
    enjoy watching ART and Showthime
    any way ART will be down from tomorrow and Showtime will follow it later..
    but anyway it's the method if they would be available later on...
    Dr-Net
