Results 1 to 6 of 6
    May 2007
    Down the road
    Default Starting Dreambox same Cam same channel
    How do I go about getting the same cam and channel each time I start up the Dreambox? Done it once before but can't remember how.
    Jed, KSA
    Go to the channel and with OSD click menu. you will get many option. click on set as startup service. and make the cam sticky. that all
    May 2007
    Down the road
    Quote Originally Posted by afridij View Post
    Can't find set as startup although I did before, had to re flash today could I have lost this option somehow? Using Gemini 4.0
    May 2007
    Down the road
    Found it, thanks a lot.
    Jed, KSA
    you are welcome
    May 2007
    Down the road
    How do I make the cam sticky? Have to re select the cam each time I turn it on. Of course this could be a safeguard in case someone wanted to see what providers your watching. They would have to learn a bit about Dreamboxes, to be able to do that.
