Results 1 to 12 of 12
    May 2007
    Down the road
    Default Please help me troubleshoot Dreambox
    Dreambox worked fine last night, but when I turned it on this morning I couldn't get any reception. Checked with control center to see if network is OK, and it shows that all is connected. Checked the wire from dish to the house, no breaks etc.. The dish itself seems not to have moved, also no high winds during the night. Can use PC to change channels, and the bottom menu is displayed with SNR 91%, AGC 88%,BER 0.
    The show currently playing is blank, the title not written at the bottom of screen when the menu is briefly displayed upon changing channels, although all shows are listed in the Enigma Web Interface. Also cannot view FTA channel. The only thing which seems to be left for me to check would be the LNB. How do I do that, and do you have any further ideas?
    May 2007
    Down the road
    Thanks for all the help. I figured it out, and got everything working.
    Apr 2008
    India
    Smile
    mellow , how do u change dreambox channels from the pc, is there some software where i can change dreambox channels from pc while viewing it on tv
    Quote Originally Posted by Dushie View Post
    if u type the lan address of ur dreambox in ur browser,,,then log in with ur username password,,,u will get an interface to control most functions of ur box
    cheers,,,dave
    May 2007
    Down the road
    Enter your Dreambox IP address into your browser
    http://www.rdi-board.com/showthread....reambox+Manual
    user-root
    pass-dreambox
    read the thread in the link above
    good luck.
    Jun 2005
    Australia
    Well go on mellow, post us what the problem was. Thats how we all learn
    May 2007
    Down the road
    Quote Originally Posted by weirdo View Post
    Don't know what caused the problem, turned off the dreambox the night before, and the next morning it wouldn't work anymore. I used FlashWizard and re installed the latest saved Gemini image, had to re download the Cam I was using. I also had my last Dreambox edit file in the PC, so that also helped a lot, I guess being taught to save these files and backup the image just paid off. I was going nuts trying to find the problem, and checked all the wires, settings, connectivity, till this was my only option other than somehow testing the LNB, which I don't know how. Anyways I'm sure glad this worked out.
    R-D-I SPONSOR Mentor
    Thailand
    Default re
    Next time u have this problem
    Goto Menu / shutdown / reboot
    This will solve the Problem
    There is no need to reflash your dreambox
    Africa-Kenya-Nbi
    When you use dreambox control centre (DCC)on your pc, look at the top rhs and you will see a remote, when the the ip addresses are linked as usual and dm connected to comp; click the remote on top and use like any other but now with your comp mouse.
    May 2007
    Down the road
    Quote Originally Posted by EDIRECT View Post
    If it happens again I will certainly try that first. thanks.
    Jun 2005
    Australia
    Thanks mellow, good to hear you got your problem sorted
    Quote Originally Posted by mellow View Post
    do this with ANY computing stuffs on your house, be it decoders, mp3 players, flash disks, pc, etc. you don't know when these things will break down.
