Results 1 to 11 of 11
    abuawab
    Default help needed with MAX 1000
    dear freinds
    this is my first post to this forum
    i'm the proud owner of MAX 1000
    BT : 1.34 SW : v1.33 K : 70
    since the afternoon of this day 11th of may 2008 , i'm trying to view SHOWTIME , ORBIT ...ets with no luck
    i went to
    - MENU
    - INTERNET
    - S/W UPDATE
    any any where i go from there i can't get any answer , if i asked for SOFTWARE CHECK, SOFTWARE DOWNLOAD , or KEYS DOWNLAS the reciever shows the massege DON'T TURN YOUR RECEIVER but nothing else , nothing is moving
    where is the problem ?
    and more importently , how can i solve it ?
    Feb 2008
    Are you sure you are connected to the internet?
    Do you have the FTA channels on Arabsat and Nilesat?
    theone01
    Innovative / Maxx 1000
    it could be that the server is down, try it again at a later time.
    abuawab
    Quote Originally Posted by theone01 View Post
    hi dear
    i'm sure that the net is working
    it gives me a massege that net is OK but channels are scrumbled
    all FTA channels are working fine
    abuawab
    thax 4 replying
    t doesn't give the massege ( error connecting to server ) it just keep showing the gray background ,and nothing else.
    i tried the receiver in another place , nothing changed
    abuawab
    the nassege says
    key software update
    do not turn of the set
    nothing else
    the bar is empty and there are no numbers
    heeeeelpppp
    Default maxx 1000
    I highly doubt your internet connection is not working properly. Check for proxy or see if your pc is really connecting to the internet. IF your receiver is connected to a router, it will get ip address via dhcp and you will still get "internet on" message. Check your modem if it is really connected to the net.
    abuawab
    suddenly
    everything is working fine
    except
    ORBIT
    can you give me the working frequalties for it ?
    May 2008
    Dubai,UAE
    the orbit channels dont work on these recievers any more,,only showtime n art
    Feb 2008
    The ORBIT, ART and SHOWTIME are all clearing on the Maxx 1000.
    theone01
    middle-earth
    if your version is BT:1.34 SW: V1.32.8 K:70 is working fine! don't download anything
    unless on new mainboard you have to download this file>>>BT:1.34 SW: 1.3 K70
    Note: always set your network info on dynamic (DHCP)
