    May 2008
    Dubai,UAE
    Default need help please..........
    hi guys,,,i just bought maxx 1000...n got dish installed facing 7degrees west n im getting all the nilesat channels for free....(pay n fta)
    is there any way i can search for other channels on other satelliteswith the same dish n receiver?coz when i try the reciever comes up with search failed or smethihng
    i want channels from any other satellite.........please give me some guidance///////////
    thnx in advance//////
    Africa-Kenya-Nbi
    Quote Originally Posted by sakss View Post
    not everything in the air is free, so its best to try with your receiver and see hat else you can get,
    how about hotbird?
    May 2008
    Dubai,UAE
    how about hotbird?
    i tried 1 or 2 satellites but nothing came up?do i need another LNB or can any 1 tell me what settings i can do in order to get other channels apart from NILESAT.....FTA or PAY channels...
    May 2008
    Dubai,UAE
    n by searching other satellites will i loose my other nilsat fta and payed channels?
    Africa-Kenya-Nbi
    The search is totally dependent on what satellite the dish is set to receive and also the lnb band - like cband or ku band.
    May 2008
    Dubai,UAE
    its set to recieve nilesat n set to ku bandcan i recieve other satellites too
    Africa-Kenya-Nbi
    Yes you can tune any other satellite so long as your dish is pointed to that particular satellite you want to tune.
    If Dish is pointed to nilesat then receiver can only tune that one sat.
    If the dish is pointed to intelsat then decorder will only tune Intelsat. It all starts with which satellite you are pointing to on the dish.
