    Default Mediastar Hi Tech help agn
    hi,
    would somebody help me again with my mediastar hi tech.
    secretman007 gave me a website to download for mediastar which I did and have the file stored in my pc.
    I am afraid to do the programing cause I might destroy my stb.
    will someone give the instruction in step by step how to do it (programming)
    thank you much.
    roger26
    middle east
    Default try this site
    hello friend
    mediastar is good receiver donot worry
    u dwonload the new software polsat and tps
    is work.
    (http://www.freewebs.com/mediastarreceiver/mediastar.htm)
    try
    rizwaaan
    rizwan
    Middle East
    Dear friends Roger,
    I given the correct link for uploading the right software
    which is working fine in my receiver. Please note that
    it's non official site of the Mediastar service centre( I am
    not revealing the place ). You can trust 100%
    http://p321.com/upload/index.php?&di...tory=MEDIASTAR
    Just download the stb 1.9 version first.
    then file HITEC-11Jul2005.zip , which is a zip file extract the
    hitech.bin file to your computer desktop. hope you have cross
    connected cable ( conn. 2--3, 3--2 & 5--5). connect both ends
    to receiver and PC. keep power off your receiver. open uploader
    1.9, click load, browse the bin file. then click connect and same
    time power on your receiver(must do same time and becareful
    dont put on before click connect). so u can see the downloading
    bars in your computer. it wll go stb will stay empty, you can see
    the message flash right and upgrade complete(wait until that)
    message in your computer. so your receiver is ready. retune
    all channels and enjoy all packages.
    Learning new things
    Sep 2004
    UAE
    dont forget Menu 2580 after download, this will enable CA System in ur receiver
    Default tk u much
    Hi,
    I am Very thankful to you secretman007 for giving me the step by step procedure of how to program my mediastar rcvr. I will try to follow ur instruction and hope i can do it with ur guidance, keeping my finger cross that i can follow correctly ur instructions.
    Thank u also aslmx.
    Thank u to both of you.
    roger26
    Default Mediastar Megabox
    Hi
    Any one know if other Receivers software work on Megabox.
    Thanks
    Middle East
    Default Re: Mediastar Megabox
    Quote Originally Posted by shaloo
    Hi
    Thanks
    dont do such foolishness. that may damage ur receiver. update with the right software which coming from mediastar sources.
    Learning new things
  1. Mediastar Hi Tech
    By roger26 in forum RDI - English
    Last Post: 2nd December 2005, 11:32
  2. Mediastar Hi Tech
    Last Post: 19th September 2005, 09:48
  3. Mediastar Hi Tech
    Last Post: 18th September 2005, 10:18
  4. Mediastar Hi Tech
    Last Post: 4th September 2005, 08:19
  5. Mediastar Hi Tech help agn
    Last Post: 12th August 2005, 04:15
