Page 3 of 41 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 603
  1. #31
    Time to update ? Mentor
    Global Village
    OK,nu o sa incerc pe 4155 evo.
    Multumesc mult pentru sfaturi.Raman dator.
    Dar pentru 4155 evo nu exista un adtfel de patch?
  2. #32
    Nov 2003
    Salut ,
    Sunt la viitorul primul meu receptor /pina acum am avut
    doar ss2.
    Ati intimpinat ceva probleme sa puneti patch-ul pt strongsat 4125?
    Imi trebuie cablu null modem sau merge si cu unu normal /serial
    Vreau sa cumpar un receptor 4125 de la Elst*r.Alea oare merg patch-iuite?
    Mersi mult
  3. #33
    @Feri
    Merge Multivision. Nu ai pus cheia buna.
    @Bogdani
    Cere-i vanzatorului sa-ti puna el patchul.
  4. #34
    Mar 2003
    Quote Originally Posted by Rico
    @Feri
    @Bogdani
    Trimite-mi Te rog cheile:[email protected]
  5. #35
    Other Not Shown
    Hello To All
    Here is something to know:
    1- this group is a friendly group for talk about satellite and every thing about it
    2- every day new codes for digital satellite receivers will be send to you and you can use and enjoy it
    3- if you have any idea you can post it to ME [email protected] I will be very happy if I hear about your ideas
    4- if you have a problem you can send an Email to group [email protected] and ask it
    5- if you know answer of any question please send an answer and help your friends in this group
    I want this group become a good group for help every body who want to know any thing about satellite technology
    At the end there are some links for you:
    For more information: http://groups.yahoo.com/group/satcode
    Post message: [email protected]
    Subscribe: [email protected]
    Unsubscribe: [email protected]
    List owner: [email protected]
  6. #36
    Introducerea patch-ului in 4125Evo se poate face cu un cablu nullmodem.
    (adica cablu cu 3 fire, 2 mufe mama cu 9 pini, configuratia pinilor: 5-5,2-3,3-2)
    Aveti grija sa nu deconectati receptorul in timpul incarcarii deoarece riscati deteriorarea flash-ului.
    Dupa introducerea patch-ului dati un reset de fabrica si este OK.
    Daca intimpinati probleme apelati cu incredere la cei de la Prosat Cluj.
    Eu am avut o problema cu un 4155Evo in care am incercat sa introduc patch-ul si n-a mai pornit. L-am trimis la ei si m-au rezolvat in aceeasi zi.
  7. #37
    Mar 2003
    [quote="Rico"]@Feri
    RICO!
    Trimite Te rog cheile pt.Multivision!
    Multumesc!
    [email protected]
  8. #38
    Sunt cele de pe acest site.
  9. #39
    S-W RO
    Am incercat sa pun si eu patchul, am dat drumul la fisierul batch dar nu s-a intimplat nimic, in afara de de a rula in DOS ceva ceea ce n-am apucat sa vad ce este. Are cineva idee, dintre cei care au mai pus patchul, ce ar putea fi. Am folosit un cablu null-modem iar receptorul este din cel cu procesor STI 5518, iar patchul folosit e "4125E-spec.zip (447K) ".
    PLS Help!
  10. #40
    Pana acum am pachuit 9 bucati, cu cablu obisnuit 2-3, 3-2, 5-5. Cu fisierul batch rulat trebuie sa apara versiunea soft "Unknown Soldier dead in 09 May 1945" si lasi pana gata progresul kB. Totul merge automat. La final ... scoti receiverul din priza si bagi iara ... altfel nu pleaca de pe buton Stand By. Recunosc ca una bucata am bulit-o de la inceput. S-o blocat si nu mai misca nimic. O fi scapat prin stoc si una din prima revizie ... Incearca sa pui soft oficial, dupa care incarca iara ...
    Bafta,
    ovex
  11. #41
    Apr 2004
    arround the world
    De unde iau si eu patch-ul?
  12. #42
    Default ok
    @ Ovex . Am patchuit si eu o gramada (din fericire inca n-am stricat nimic). Oare receiverele de la D&K (strong 4125 - care nu prea seamana cu cele pe care le-am patchuit) sunt bune pentru modificare ? Sau doar poza de pe site-ul lor nu este adecvata!
  13. #43
    @Criztian[STATiON]
    Nu am spus ca l-am stricat! Am precizat: Dupa blocaj, am pus softul oficial si am reluat dinou patchuirea si a mers.
    Asta recomand, dar firmware oficial pe net i-l gasesti numai daca dai spaga lui NETU
    ovex
  14. #44
    S-W RO
    Am reusit pina la urma cu patchul... Problema era ca aveam COM 1 ocupat de un alt program (girder=telecomanda la SS2) si nu ma lasa sa comunic cu receiverul...Deci vedeti ce faceti, sa nu patiti la fel . Cit despre pathul oficial, nu trebe "spaga" decit poate la GOOGLE .
  15. #45
    @barghy
    Eu sunt pentru progres si nu pentru regres ... si sincer ma bucur ca ai reusit. Pe bune! Dar soft oficial pentru 4125 am gasit numai pe unul olandez, care aparea, te arunca in cel oficial, care nu deschidea pagina respectiva "page cannot be found" si pe cal ungurean care este dinou in constructie ... s.a.m.d. DEZASTRU!
    Vedeti daca puteti lua ceva de pe www.strongsat.ro www.strongsat.com
    ovex
  1. strong 4125 evolution
    By alex1 in forum SD Receivers
    Last Post: 21st January 2007, 23:08
  2. decodare cu srt 4125 evolution ?
    By nikiad1 in forum SD Receivers
    Last Post: 18th June 2006, 11:03
  3. Upgrade Firmware - Strong 4125 Evolution
    By AlaMicSiNegru in forum SD Receivers
    Last Post: 2nd June 2006, 16:03
  4. Replies: 0
    Last Post: 28th April 2006, 03:21
  5. Replies: 7
    Last Post: 4th April 2006, 05:55
