    zzzzzzzzzzzzz Expert
    rdi
    Default HDMI over Ethernet solution ???
    ce-i asta ca nu inteleg
    HDMI over CAT-5/6 - BVHD-10
    BVHD-10TM
    Deliver HDMI Over CAT-5/6
    As the pioneers of Audio and Video over CAT-5 and CAT-6, you can trust that AudioControl's BVHD-10 system will accurately and reliably extend HDMI signals over CAT-5 or CAT-6 up to 150 feet. The BVHD-10 sexxx HDMI v1.3 over a pair of standard CAT-5/6 cables, providing more flexibility in the installation and offering a much more affordable and compact solution than attempting to use standard expensive HDMI cable.
    The Power to Go The Distance
    The BVHD-10 system includes the HDD-10 sender, HDR-10 receiver, and a 12-volt Wall Plug Power Supply, which powers both units from either end, making installation even easier. Utilizes unique adaptive equalization technique for automatic signal restoration.
    Bulletproof Reliability
    The BVHD-10 system is designed and built at our factories in the Pacific Northwest Rainforest to ensure product performance, and is backed with our Bulletproof 5 Year Warranty.
    xxx Features
    * Newest Generation HDMI Signal Processing
    * Active and Automatic Signal Restoration
    * LED Confirmation of Valid Connections and Data Transfer
    * Long Cable Length: Up to 150 feet for 1080p, 200 feet for 1080i
    * Accomodates all HDMI/HDCP v1.3 Signals
    * Locking HDMI Connector Type
    * Externally Powered for Best Performance
    * Special Static Protection on All Inputs and Outputs
    * 5-Year Warranty When Dealer Installed
    * Designed and Manufactured at the AudioControl Factory in the Pacific Northwest Rainforest of the U.S.
    http://www.wholehouseaudiocontrol.co...duct_Id=258502 (nomentan nu merge)
    O veste buna pentru cluburi , discoteci, hoteluri ...
    Aiurea veste buna!
    Este un adaptor pentru a transmite semnalul HDMI la distante mari folosind cablul UTP.
    Exista asemenea adaptoare si pentru batranul semnal videocomplex.
    Era o afacere pentru hoteluri daca mergea macar ca un splitter dar, din pacate, este punct la punct!
    SS1 v.1.3 / DM500S, KSF200, HSS 1160, HSS 3169, DM600 / H-H DG120 Plus, STRONG 10" / 1.15AL, 0.9FE, 0.8FE, 0.4FE / DiGi / Focus
    __________________________________________________ ______
    E placut ca altcineva sa-ti rezolve problemele, dar nu e obligatoriu!
    Fan Barca Teacher
    Quote Originally Posted by adison View Post
    Aiurea veste buna!
    Et voila aici este ceva care itzi gaseste sensul la intrebarea pusa
    http://www.casanova-sas.fr/
    http://www.casanova-sas.fr/images_co...r/fiche_16.pdf
    O zi buna
