    Mar 2008
    Default HOW TO JTAG Strong 4652 Receiver ??? HELP me ! Please
    hello,i can not read or write english very well !
    i have SRT4652 (none X),i upgrade it with SRT4620II_4650_193p_20080325.stb patch file.then my SRT4652 worcking Ok for 30min almost,then HANGED & display 1 on itself after few seconds display 1 1 on itself & i power off it with powerkey on back panel,when power on it my SRT4652 dose not work and dose not BOOT,i try reupgrade this BUT loder dose not connect to my SRT4652 ! can you learn me about HOW TO CREATE JTAG CABLE FOR SRT4652 & HOW JTAG SRT4652 ! PLEASE HELP ME Soon...
    < Below link contain Strong 4652 Receiver Board & CPU & IC-Flash Photo(s) >
    http://www.ufile.info/upload/1206685746.zip
    CPU:
    CONEXANT
    MPEG II DECODER
    CX24142-15AZ63008608
    625 KR
    ARM
    AN IC:
    MX T064020
    29LV160CTTC-70G
    2S085600
    TAIWAN
    ANOTHER IC:
    ELPIDA TAIWAN
    S6416 AHAT-6B-E
    0434CR 180000
    i have boot file (boot_cpu cx24142-15az_flash sst39vf1601.bin)
    i have EJTAG Tiny Tools v1.0.6.12(For flash CONEXANT CPU)
    i have Jkeys 2.9.12
    >>>i know it made in chine & I WANT HELP about HOW TO CREATE JTAG CABLE FOR SRT4652 & HOW JTAG SRT4652! PLEASE Help Me.
    [email protected]
    THANK YOU.
    Mar 2008
    Default CONEXANT CPU + MX T064020 29LV160CTTC-70G FlashIC + EJTAG_TT + EJTAG.ini + SRT4652 !
    Hi, I have big problam & Very Professional Question !?
    for one step please download this : http://www.zshare.net/download/9828393e37df0b
    I want JTAG SRT4652 with CONEXANT cpu & MX T064020 29LV160CTTC-70G FlashIC, it must jtag with EJTAG_TT_1.0.6.12 ,this
    software has a EJTAG.ini file,it is an definition file same jKeys.def for Jkeys software. BUT EJTAG.ini has special Syntax and i want help
    me to learn EJTAG.ini Syntax and how configuration EJTAG.ini for CONEXANT cpu & MX T064020 29LV160CTTC-70G flash IC ?
    So uploaded file contain a sample EJTAG.ini ready to use for Starsat4000 & Ali cpu model type C.But don't work in CONEXANT cpu & MX
    T064020 29LV160CTTC-70G ! and uploaded file contain few photo from error in EJTAG_TT_1.0.6.12 ( EJTAG.ini contain FlashID number
    + address of Erase-able FlasIC Block(s) + FlashSize ). Now i want make EJTAG.ini ready to use for CONEXANT cpu & MX T064020
    29LV160CTTC-70G ?!?
    Attention : If EJTAG.ini does not contain you're FlashID,Application Stop And doesn't work,So i insert my FlashID (0027) into EJTAG.ini
    manualy,But when application try to Erase target Block(s) in FlashIC,Return error ( Error Eraseing Block ... (in photo named 2.jpg) )
    The author Site www.tele-sat.ru/forum provide full learn of configuration EJTAG.ini for any CPU & FlashIC type(s).But isn't English
    or Persian Language and i can't read this! Do you known Russian language's
    I think all necessary information in a ( Flash-IC-DATASHEET ) file for example :
    You must have,
    1_ Starsat 4000 Flash-IC-DATASHEET file. (use www.DataSheetArchive.com)
    2_ EJTAG.ini ready to use for Starsat4000. (use uploaded file)
    3_ Strong 4652 Flash-IC-DATASHEET file. (use www.DataSheetArchive.com)
    4_ knowledge for read Flash-IC-DATASHEET file(s).
    OR
    You must have,
    1_ Starsat4000 Flash-IC information jKeys.def file. (in jKeys folder)
    3_ Strong 4652 4000 Flash-IC information jKeys.def file.
    4_ knowledge for read jKeys.def file.
    OR
    Many more way ! Only must knowledge !
    Congratulate you can write all necessary information for any CPU & FlashIC type(s) in EJTAG.ini accurately and JTAG with
    EJTAG_TT_1.0.6.12 software and finally HELP TO MANY PEOPLE TO USE EJTAG_TT_1.0.6.12. -- THANK YOU --
    [email protected]
    Mar 2008
    hi my frind mrhamed.i have the same broplem with my SR-x1800 super (conexant cpu) withe this jtag :
    I Have just one quistion :
    Is the software EJTAG_TT rocgnaze ur cpu?
    caus ther are many receiver looked hardware..
    Apr 2008
    Over Side Of The Hill From Down The Road
    International Satellite Forum
    We give u what others dont
    Files / Keys / MP3 / Adult XXX Movies
    www.satelliteforum.net
    Mar 2008
    Hi, bioidr & allI read ENGLISH very hardlly ! you're comment is english ? ...For ARM9 Cpu type (Conexant), LPT to 20pin Jtag type for use EJTAG must be :JTag pin1 and pin2 is VCC 3.3v (not necessary)LPT2 (R100 ohm) > TCK JTag pin9LPT3 (R100 ohm) > TMS JTag pin7LPT8 (R100 ohm) > TDI JTag pin5LPT11 (R35 ohm) > TDO JTag pin13LPT 15,18,19,20,21,22,23,24,25 (wihout R) is must conect together = GND JTag pin 4,6,8,10,12,14,16,18,20 is GND conect together by Manufacture = GNDSo on off LPT-GND > one of JTag pin-GNDMy flash type is MX e jtag only Erase EJTAG can Erase 16 blocks & i don't known other Flash-IC type this version of EJTAG can only read and can't Write Flash with CONEXANT cpu.I and many people are standby for new release of EJTag with WRITE-FLASH Capability in Conexant.find out : http://forum.tele-sat.ru/showthread.php?t=1064&page=3 can download last version of EJtag : http://www.zshare.net/download/9957787c700c37/But if you want try more, use 'H-Jtag' Software it is powerfull tool for jtag CONEXANT cpu type, needs read carefully ' User Manul.pdf ' it contain one jtag schema of JTAG cable for use H-jtag, Must made it exactly !you can download H-JTAG + User Manul.pdf in one Zip & Rar Package from :http://www.hjtag.com/download/H-JTAG%20V0.6.1.rar THANK YOU.
    Mar 2008
    HI, mrhamed and All friend .Sorry for my bed English but I try ameliorate it .
    Thanks for the explanation but I have other question I wile send it at your E-mail ,of cors if you permit.
    Mar 2008
    sorry for late reply
    you can send to me mail about & cooprate to try jtag ARM9,i'm from iran_tehran.
    [email protected]
    Mar 2008
    Default Conexant Cpu J-Tag Ready !
    hi
    you can J-Tag all ARM 7/9 Processor type now !
    Please download one of below links :
    http://www.zshare.net/download/11546789497b34a5/
    or
    http://rapidshare.com/files/11262927....6.14.rar.html
    or
    http://www.crosat.org/aploud/index.p...G%20RECEIVERS&
    password: (MCSPG)
    THANK YOU !
