Results 1 to 11 of 11
    i think this is a bug with altdvb or something. When setting up a C-Band sat, select "Ku Linear" for the LOF Setting/LNB Type. This gives 9750000/11700000/10600000 you may have to change it to 9750000/0/10750000, depending on your lnb setting.
    After that you have to convert the C-Band freq into a Ku freq by deducting the C-Band freq from 14900. Edit your transponder list as needed. Enter the result as the freq to be scanned.
    The S/R remains the same in value.
    Example: For C-Band freq 4180 Mhz enter 10720 (14900 - 4180).
    try to scan using this method and let us know of the results.
    Jun 2007
    Even I am unable to selcet the Technotrend card in DREAMDVB
    yeah, they may have overlooked the cband aspect, that's why the deductions of frequencies to let the software "think" it is scanning Ku signals - may help you in the future if your signal keeps on failing.
    Jun 2007
    Ansish give me link where I can Download Latest ALTDVB SW
    -http://altdvb.dvb-skystar-2.com/
    Jul 2005
    india
    here new Altdvb Star Edition 2:
    http://www.zshare.net/download/3706377faeaef1/
    (KANNAL PARPATHUM POI.KATHAAL KERPPATHUM POI.PRACTICLES ONLY MEI)
    http://sharafscs.blogspot.in/
    Jun 2007
    Thanks Sharaf
    Jun 2007
    I loaded this But its Not Compatable with TechnoTrend PCI DVB cards...
    Jul 2005
    india
    Quote Originally Posted by anishpsla View Post
    Please help me to solve this problem
    check your PM..
    you could have posted your solution here.
    i was referring to Sharaf. solutions should be made in public to help others too.
