Results 1 to 2 of 2
    Dec 2007
    Kolkatta
    Default Connection Problem - DreamBox with Dial-up Connection
    Hello Friends,
    My present set-up is
    1. Laptop connected to intenet via Dial-up connection -- Speed: 44 kbps (ie Rate of Speed is 3 KB/Sec)
    2. Laptop and DM are connected via Network card through ethernet 8-port hub
    My DM is connected to intenet with this set-up. To this i checked by downloading DM image..and hence DM accessing intenet can be seen in my laptop with proxy softwares.
    I have inserted a c-line in my DM, Also i called my server guys and found that my ip is visible to them, but i cant seen any pictures.
    Any one tell me is the set-up work fine (or) anything i have to modify.
    Tell me what is the minimum data transfer speed required to connect the server from DM.
    I heard lot of members are using the dial-up set-up for their DM and requesting to help me....
    Thanks....for all
    Super Moderator Expert
    bucharest
    the speed of conection is too low/use a lan conection or broadband
