Results 1 to 10 of 10
    Mar 2008
    Dubai
    Default Error FEAA, need help with EL-700 FTA+ upgrade
    Hi folks!
    Bought this Echolink EL-700 FTA+ in the UAE but I cannot upgrade the software available on the SRS website. Maybe I'm missing a step. It is my first time to do this for this box. I have done other receivers like the TechnoSat 6000plus without any problems.
    I have tried it on a XP and Vista platform with port settings 11500 baud, parity even.
    Used a 9 pin nulmodem cable 2-3, 3-2, 5-5.
    When switching on the receiver, after having started ALIMUPG51, it try to connect to the receiver.
    It says:
    Please power on your STB.
    Open Serial Port..
    Sync to serial port..
    Target not connect or target is error status!
    Then my receiver Errors "FEAA" whatever it means.
    Any suggestions.
    Eddy
    Jun 2007
    Hi,
    if you don't mind just send me your email address i will send to you the procedure and loader for upgrading of Echolink.
    [email protected]
    Mar 2008
    Dubai
    Default email send
    have send you an email
    Mar 2008
    Dubai
    Default current sw
    bootloader 0.9.6
    Maincode 1.3.6
    Cas_data 1.0.0
    defaultdb 1.0.0
    mcu version 1.1.2
    manufact 14C35E
    Product XXA547F41
    Aug 2004
    M east
    Quote Originally Posted by eddy123 View Post
    Hi folks!
    It says:
    Open Serial Port..
    Any suggestions.
    Eddy
    You can use only ALIMUPG5 loder only and the software only 23 02 08dated pls not use the super software.
    Tech
    Mar 2008
    Dubai
    Default still doesn't work
    I have tried ALIMUPG version 4 and followed Oto's instructions, version 5 and 5.1 but none is successful. I notice that the software uses port on com 1; with parity even and bit rate 115200. Now by default the port settings are; parity none and bit rate 9600.
    I have changed the port settings to match the software but still no luck. It always errors with FEAA, whatever it means.
    Is my bootloader OK?
    Any other idea's I'm running out.
    Eddy
    Aug 2004
    M east
    Eddy
    Check ALIMUPG 3 and old software try to load receiver after you can up grade by ALIMUG 5.
    Tech
    Mar 2008
    Dubai
    Default where to get?
    I have Googled on version 3 but cannot find it. Can you show me where this version can be downloaded?
    Aug 2004
    M east
    If it is not possible you run a diffrent software in this box, try the shope from where you the box they do that, no charge...
    Tech
    aafaqhassan
    Default Software Problem
    I have digital receiver echolink EL-700 FTA+. Multivision and some
    other packages are not coming for about six days, please send me
    reason and how can I get these channels again?
    My software details are following:
    bootloader 0.9.9
    maincode 1.3.7
    Cas_data 1.0.0
    Default db 1.0.2
    mcu Version 1.12
    manufact 147538
    Product XX3547F41
