    In everybody's heart
    Default Diseqc switch doesn't work with Skystar2 any solution?
    Diseqc switch doesn't work with Skystar2 any solution? switching between satellites is problem sometimes no signal at one satellite and sometimes at another.
    Good things comes to those who wait.
    Africa-Kenya-Nbi
    Some of the softwares dont work with Diseqc,
    try ProgDvb, or Mytheatre, the two should have controls for diseqc, unless you are using the softwares already, and a problem has occured.
    What type is the switch you are using? Some of them are cheap and poor quality, they have problems by switching, most during bad or cold weather. Try the Spaun switches, they are the best and you will never have problems.
    Chennai, India
    Quote Originally Posted by wiseguy4u View Post
    Diseqc switch must be the problem.
    Oct 2006
    greenwich
    it`s one of the problems diseq develops,mainly when you switch between satellites with diferent polarizations,try to switch chanells from separate satellites with the same polarization and there won`t be any troubles.hopes that helps.
    Feb 2008
    Dear use old Diseg switch if u get 4rm some whr same problem I faced wid my dreambox once replaced d switch thr was no problem
    Thanks for everybody advice.
    I am using DVBdream but same problem exists with Technisat SERVER4PC
    which comes with skystar2. I have tried 2 other brand switches but same problem
    exists with only skystar2 card but not with my receiver (STB). Anyways I will try to
    find any expensive imported switch.
    My driver version is 4.4.1 BETA.
