    Sep 2007
    Default problem with my dreambox
    dear friends i have this problem i need your help every time i change image the diseq gets distroyed i dont know if it is the diseq or another problem but i know every time i change image it will not work till i change the diseq
    Jun 2005
    Australia
    Quote Originally Posted by castro View Post
    That's normal castro, after you change images you have to set the diseqc/LNB settings again.
    hi castro,,,do u mean the software settings,,,or the hardware diseqc switch
    cheers,,,dave
    SATELLITE GURU Expert
    Quote Originally Posted by weirdo View Post
    Thats a pain in the arse then.... with my receivers I just change channels from one satellite to another ... but then again I have no images but do have diseqc settings.
    Sep 2007
    normaly i change every time when a new image is out just for test now my receiver ithink is the hardware diseqc switch is gone completely realy idont know what is the problem because it will start serching then stops signal is not found or it can do complete service serch but in few minutes later is off no signal i tested all diseqc wich i changed are working with another receivers any idea? try to think with me pls!
