    Apr 2004
    Default Strong Reciever Problem
    Hi to all RDI friend guys i need your help to my strong reciever i can't see the nagra key section how can i open the key section. pls help me
    advance thanks to all
    triphop
    Master Baker Junior
    May 2004
    Bangkusay
    Default RE: Strong Reciever Problem
    Quote Originally Posted by triphop
    To open Strong SRT satreceiver’s Keys Menu, you’ll have to press ”8282” alpha–numeric buttons of your remote control. Have you tried that, tóls?
    Apr 2004
    Thanks you mr. dhunny i tried to press "8282" but not display the nagra key section any other code.
    triphop
    KSA
    Default Re: Strong Reciever Problem
    triphop
    After pressing "8282" various key captions will appear, just search for Nagaravision using the remote control.
    Apr 2004
    guys any other code for strong receiver to open up the nagra key section I tried the "8282" but nothing happen. there's any defualt code to open up the nagra key section.
    triphop
    Sep 2003
    Philippines
    Default Strong Receiver
    Hi,
    When you enter 8282 code edit will appear for Nagra, but you have to scroll until you reach nagra section which is around line 90 upward.
    If you are not familiar just check the Provider names like Polsat, Dish, BEV, Dream, ABS-CBN they are using nagravision so at least you are almost on the section you want to edit.
    Make a try, no pain no gain.
    Cheers,
    johnpal
    triphop
    ?I think your receiver does not support 8282 feature at all.
    Indonesia
    Can you tell me the tipe
    Terrorist use the muslim faith for there privat intrests, and should be killed more painfull than their victems
  1. Strong reciever uptodate site
    By july61981 in forum RDI - English
    Last Post: 18th September 2006, 08:57
  2. dear friend problem update echostar reciever help........
    By israrkhan in forum RDI - English
    Last Post: 10th July 2006, 04:11
  3. Reciever Strong 4355 2xCI, 170 RON!
    By zaiclopz in forum Shop
    Last Post: 9th July 2006, 19:48
  4. strong reciever AU???
    By maiques2002 in forum RDI - English
    Last Post: 29th May 2006, 23:43
  5. Strong reciever patch website....??
    By g212vkl in forum RDI - English
    Last Post: 21st July 2005, 08:30
