    Aug 2004
    Default xsat dual sim problem on Dr**m
    My dual sim is not functioning well since last week on dre**m. It turns on and off every 12 seconds. Just want to ask what to do best to correct this problem. Do I need to change to single sim (Fun 4 card)?
    Apr 2004
    Philippines
    1. Try removing the funcard while on encrypted channel,
    2. tune on FTA channels if your Xsat still turns off every 12 seconds.
    3.try to reload the software of your receiver.
    If your funcard has propblems, the receiver cannot read it, and wont keep on rebooting.
    Hope this helps.
    Aug 2004
    Default Dual sim card
    Im using this card for two months and its okay but until last week when it break down. Not only me that this dual sim card turns on and off but in all dual sim users. This card is not a fun4 card. This card is white in color and has name in here nagra vision.
    HONG KONG
    Default Re: Dual sim card
    Quote Originally Posted by edersson
    yes dear u need new file white card
    fun 4 is ok only white card break down
    Senior Member Teacher
    May 2005
    On The Move
    Default Re: xsat dual sim problem on Dr**m
    dear friend ,
    same problem with me on X-SAT for last two weeks but i have changed the card and my problem has solved.
    try to to get the new card or file for your new dream
    ART IS TO COMMUNICATE.....
    Aug 2004
    Dear friend,
    where can i get the new correct file?
    May 2005
    On The Move
    Dear friend,
    pls provide your email address.
    i will send u the fun 4 file for ur auto dream.
    regards have fun.
    Aug 2004
    Default My email edrz
    My email adrez [email protected]
    Thanks for the help!
  1. DUAL LNB.
    By dawar098 in forum RDI - English
    Last Post: 1st November 2006, 07:29
  2. Dual CA
    By nicnec in forum RDI - Satelit
    Last Post: 14th June 2006, 23:11
  3. Dual Band LNB
    By Shakin in forum RDI - English
    Last Post: 29th May 2006, 23:40
  4. Dual feed !?!
    By johnny-m in forum RDI - Satelit
    Last Post: 21st January 2006, 14:44
