Results 1 to 2 of 2
    May 2007
    Thumbs up Satellite Antenna Alignment 2.38.0
    Satellite Antenna Alignment 2.38.0 | 1,48 MB
    The program "Satellite Antenna Alignment" is used to calculate the angles necessary for installing satellite dishes. The main difference from similar software is the possibility to calculate the position for all satellites at once. Thus, you get a clear picture about what satellites can be physically visible from the location where the dish will be installed. It should be kept in mind that the program makes a purely theoretical calculation according to formulas and in real circumstances a lot of additional factors should be taken into account when a satellite dish is installed. These factors include various obstacles (buildings, trees), the landscape, the altitude, transponder orientation, polarization, etc. Nevertheless, this program will allow you to evaluate the position quite precisely. The calculation can be saved to a text file, copied to the Windows clipboard or printed out at once.
    Rapidshare
    ... strong like Baloo The Bear !
    www.xmissy.nl
    www.dump.com
    www.redtube.com
    Latitude: 44.455°
    Longitude: 26.048°
    Latitude: -42.869°
    Longitude: 147.328°
    Latitude: -46.404°
    Longitude: 168.356°
    http://www.rdi-board.com/showpost.ph...1&postcount=20
    http://www.rdi-board.com/showpost.ph...1&postcount=25
    pentru ce mizerii a scris aici nenea ********de sw astept scuze ! daca nu ma retrag de pe rdi !
    Nepriceput in multe Expert
    Feb 2006
    SIBIU
    Quote Originally Posted by ursul baloo View Post
    [IMG]pg[/IMG]
    Rapidshare
    ursule cred ca s-a mai spus de programul asta
    nu stiu daca exact aceasta varianta ,
    dar in orice caz era acelasi program
    era varianta 2.36.8 cred
    deci ce aduce nou fata de aia ?
