Page 1 of 4 123 ... LastLast
Results 1 to 15 of 55
    Jed, KSA
    Default Need Help to use more then 4 Lnb in DM 500S
    Can someone guide how to see more then 4 Lnb in DreamBox 500 receiver.
    Thanks
    THAILAND
    Quote Originally Posted by afridij View Post
    Thanks
    Anyone know a brand of 0/22khz switches that pass through the Disecq commands ?
    When we discover that brand we can solve the problem cheaply and easily.
    Other solutions out there available ie 1 in 8 switches and Spaun.
    Jed, KSA
    But where will we put this 0/22 khz in Dreambox 500 as there is nothing behind to put this switch and please let me more of Spaun.
    Thanks
    google is your friend. or use the search function of this forum since a LOT has been said about this kind of thread already.
    Alexandr
    Thanks
    You need DiSEqC 1.1 1/8 or 1/10 LNB. Or switch 0/12V + 2x DiSEqC 1.0 1/4
    SATELLITE GURU Expert
    For more than 4 LNB's you cannot use one disqc and you will have voltage issues unless you use the proper equipment.
    he can use 2 4in1 disecq with 22Khz tone switch automatic or manual.
    or just use a multiswitch. period.
    Jun 2007
    Quote Originally Posted by irdeto2engineer View Post
    Hi Iredoengineer2,
    sir if I use 2 Diseq and 1 22khz switch I think it will also work the same
    and in Dreambox for 1,2,3,4 use 1 Diseq and for 5,to 8 use other Diseq and both the Diseq out put given in 22khz switch I think IT will work the same.
    Regards,
    BLR
    Hi Iredoengineer2,
    Regards,
    BLR
    YEs it may work the same until you wan to add more than one receiver..... Thats the difference with a multiswitch is that you can add many receivers.
    Jun 2007
    Yes Iredoengineer2 You are 100% correct thanks.....
    Tomorrow I will receive my 22khz switch I will test that in DM and let all know my Result...
    Regards,
    BLR
    THAILAND
    Default re ONE RECEIVER and multiple lnbs
    Oh heavens ..Please stop talking of using a 22kh tone switch with two 4 OR 8 port diseqcs
    UNLESS you can provide the name of a brand of 22khz switch that will allow the disecq signals through. I have three brands already that won't but people say there ARE brands that can do this.
    PLEASE NAME THOSE BRANDS and where they are sold as I want to buy half a dozen such 22khz tone switches .
    Many thanks.
    Jun 2007
    Many thanks.
    Why C BAND According to u some of the 22khz Switch will work with 2 DISEQ not all 22khz switch will allow diseQ as in put ?
    THAILAND
    Default Posting concerning only ONE RECEIVER and multiple lnbs
    Heaven knows why but the three 22khz tone switches I have will not pass through the diseqc signals properly . Others say their 22khz tone switches they have will do this and I am certain they are telling the truth.
    Buy one yourself...they cost only a couple of dollars and see if yours will work
    Trial and Error...let us know the result with yours.
    Don't know why you are bein so niggardly... the switch above I posted does what you want.
    So buy the correct gear get your systems working properly.
    There are 22khz switches that can be used with UNVERSAL LNB on 22khz plus another lnb on the other port. I use them here but rarely.
    Jed, KSA
    I have 22khz switch but dont know how to connect it to Dreambox 500. Please help
