Results 1 to 15 of 22
    Default some strang problem
    dear DM experts, my DM doesn't "lock" signal in some tps and but "locked" some tps..for example..it can got signal for 3660v @telstar18 but doesn't with 3600v....any solution?
    i have tried with some different images also!
    Maseru, Lesotho
    Hello George,
    Could it be the skew of your LNB?
    I had no problem with my C Band 2,4 M mesh dish on NSS7, but when moved to Intelsat 7/10 I had to move my LNB clockwise about 30 degrees to get both the H and V MC ch's
    Hope this helps.
    Regards
    DM500S, FortecStar Alpha, Lifetime Ultra, Lifetime Classic:
    Intelsat 7/10, TelStar 12 and NSS 7
    Time spent on Reconnaissance is seldom wasted.
    Quote Originally Posted by Boknaaai View Post
    Hello George,
    Hope this helps.
    Regards
    actually this not a problem of dish or lnb cozed all other stb s working great and also other DM r also working perfect and problem is in only particular DM!
    thank u for the reply!
    Maseru, Lesotho
    All understood, hope you get it resolved
    Regards
    Regards
    NOT YET, may b the TUNER problem....
    MVDIG Teacher
    Maldives
    Most chinease made dreambox have this issue some frequency not lock
    Jan 2008
    bro, i had the same problem with clone boxes, its the weak tuner that causing the problem, i've now connected the dish directly to dm instead of looping out from my topfield and it (dm) seems to lock after that.
    Quote Originally Posted by junaid View Post
    yes junaid u r correct, but this is first experience to me!
    Quote Originally Posted by sawasdee View Post
    hmmm, i already connected directly!
    Australia
    I got a Clone DM500s with Gemini image,It locks on Tp 3599 but not 3660 on a 1.8m Solid..
    Quote Originally Posted by Aldeto View Post
    hmm! its very strange............!
    alanpaladka
    Even I'm also having same problem with my DM on Dish TV transponders. Some get locked but some isn't. May be its a common problem with clones.
    SATELLITE GURU Expert
    Quote Originally Posted by alanpaladka View Post
    Very common with clones to have bad tuners.
    Quote Originally Posted by irdeto2engineer View Post
    i had handled nearly 20 clone DMs....but only one box is having problem!
    alanpaladka
    I'm having this problem only with Dish TV Transponders. All others are working great!
