Thread: pas7
    Jan 2008
    Unhappy pas7
    hi guyz i have fortec star lifetime ultra with 60cm dish pointing 68.5 degrees east dstv dish to be polite wanted to know what channels i can get with this and can someone tell me how thanx.....
    East Malaysia
    Smile Pas 7/10
    Quote Originally Posted by venom View Post
    Bro please refer to Lyngsat.com and you will get sat **** print from sattraacker.mrtian.com. regards
    Africa-Kenya-Nbi
    Refer to lyngsat
    any help you will get is also subject to your location -
    please specify for more detail.
    Maseru, Lesotho
    Hi Venom,
    What is your location?
    Check out www.lyngsat.com/intel68.html for ch list
    Lifetime Ultra can't autorol so its either FTA ch's, or if you want SABC 123 and ETv you will have to manually enter the Nagra keys, that is assuming you have the latest AL7BAR bin file loaded. Keys available on this site.
    Check out http://www.al7bar-soft1.com/ for updated firmware.
    The LTU cant do Crypto, DMC package on Telstar 12 @ 15 Deg W (Southern Africa and Europe beam), so you are basically stuck with IS7/10 on that STB.
    Regards
    DM500S, FortecStar Alpha, Lifetime Ultra, Lifetime Classic:
    Intelsat 7/10, TelStar 12 and NSS 7
    Time spent on Reconnaissance is seldom wasted.
    Mar 2003
    98.98 East 18.56 north
    Quote Originally Posted by Boknaaai View Post
    Hi Venom,
    Regards
    him use 60 cm for DSTV
    so his Location its sout Afrika and watching only KU-Band
    Daeng
    10FT Dish 169° east-49°east
