Results 1 to 10 of 10
    THAILAND
    Default Top Marks To Top Field
    Unlike Humax which responded after several weeks to a technical inquiry I want all RDI'ERS to know that they are 100 percent safe with the Topfield brand in relation to customer service direct from Korea .
    My first question to them was answered in 12 hours , my second question in just TEN MINUTES after emailing Korea.
    I highly reccommend the TOPFIELD brand
    See below
    Dear xxxx,
    In general, satellite HD programmes are encoded by MPEG4.
    If you have no problem with watching LUXE HD TV in high definition, you will have no problem with the Voom HD TV, either.
    Regards,
    Hoze Li
    Marketing Team
    TOPFIELD
    Manaw Land
    Default TopField
    Dear C-BAND,
    Thanks for the Info.
    Some times ago, I have read somewhere there was a deal between UBC of Thailand & Humax of Korea to provide decoders for UBC which is TrueVision now.
    Nowadays what we are seeing is TopField decoders not Humax.
    Humax & TopField are same company with different product Name?
    Like National, Panasonic & Technics, they are Masushita from Japan.
    Please enlighten me if you know.
    Regards.
    THAILAND
    Quote Originally Posted by L.ZauJa View Post
    Dear C-BAND,
    Regards.
    This is what I know.
    HUMAX & TOPFIELD are both S.Korean Companies.
    Humax is very much orientated to the UK as they have a factory in Northern Ireland.
    Topfield is orientated to Germany where they have a huge market.
    I have both models...the Humax in the UK and the Topfield in Thailand.
    The Humax mentions MPEG 4 in its manual and menu.
    The Topfield makes no mention of MPEG 4 hence my worry as so many channels are now going over to MPEG 4.
    Below is the specification for the 7700HSCI....CAN YOU SEE ANY REFERENCE TO MPEG 4 ?
    USB PVR Ready
    Fully DVB-S/DVB-S2(H.264) HD compliant
    2 Common Interfaces for CONAX, CRYPTOWORKS, ******, NAGRAVISION, SECA & VIACCESS
    DiSEqC 1.0, 1.1, 1.2 and USALS(DiSEqC 1.3)
    5000 services (TV and Radio) programmable
    Multilingual audio support
    Multilingual menu text support
    Service list editing
    Favorite service list editing
    True-color On-Screen Display (OSD)
    Electronic Program Guide (EPG) for on screen service information
    Subtitle supported
    Teletext supported by VBI insertion and software emulation
    Parental lock facility by service and program event
    Firmware upgrade by USB2.0
    Firmware and Data transfer from receiver to receiver
    S/PDIF for digital audio or Dolby AC-3 bitstream output
    USB 2.0 supported for fast PC interface
    MP3 decoding
    VFD Display for service information
    Component (YPbPr) output
    Tuner & Channel Decoder
    Input/Loop through Connector F-type, IEC 169-24, Female
    Frequency Range 950 ~ 2150MHz
    LNB Power & Polarisation
    Vertical : +13.5VDC
    Horizontal: +18VDC
    Current : Max.500mA with Overload Protection
    22KHz Tone
    Frequency : 22±1KHz
    Amplitude : 0.65±0.2V
    Demodulation QPSK
    Input Symbol Rate 1?shy;45 Msps
    Code Rate 1/2, 2/3, 3/4, 5/6 and 7/8
    Transport Stream A/V Decoding
    Aspect Ratio 4:3, 16:9
    Video Resolution 576i, 576p, 720p, 1080i
    Main System
    Main Processor ST40
    A/V & Data In/Out
    HDMI HD Video/Audio Output
    TV Scart Video CVBS/S-VIDEO/RGB/YPbPr, Audio L/R output
    VCR SCART Video CVBS output
    Audio L/R output
    Video CVBS/S-VIDEO/RGB/YPbPr input for bypass
    Audio L/R input for bypass
    S-Video Video S-VIDEO output
    Component YPbPr output
    RCA A/V Video CVBS output
    Audio L/R output
    RS-232C 9 pin D-sub type
    Transfer rate : max. 115.2Kbps
    USB USB2.0 Host
    Conditional Access Interface
    PCMCIA 2 slots
    DVB Common Interface standard
    Front Panel
    Keys 5 Keys (CH-/+, VOL -/+,STANDBY)
    VFD Service information or Time display
    RCU 37 Keys
    Power Supply
    Input Voltage 90 ~ 250VAC, 50/60Hz
    Type SMPS
    Power Consumption Running : Max. 37W, Standby : 8W
    Protection
    Separate internal fuse.
    The input shall have lightning protection
    Physical Specification(340mm Model)
    Size(W x H x D) 430 x 60 x 265 mm
    Weight(net) 2.88 kg
    ps One great improvement with the Topfield. I used to HATE that make as unlike EVERY OTHER MAKE they did not allow you to add or change sat names. Thus if you bought the box in Germany there was no Panamsat 2 or 8 !
    You had to download software for extra channels ...if you knew how !
    Now they have a sat name edit function just like all other receivers.
    I think they listened to my complaints and that of others.
    Feb 2007
    Negombo, Sri Lanka
    Manhattan customer care is hopeless.
    Emails sent to their email address get returned eternally !
    DM 600+80GB DM 7020+160GB+ LED 55"
    Manaw Land
    Default TopField
    Thanks for the long Specification of 7700HSCI.
    Regards.
    21.95° N 97.06° E
    One of my friend from S.Korea , bring a receiver to me which is Topfield 3100 FEI and he said that most Korean use this product in Korea.But now , he left his receiver to me and bring my Dynasat receiver bcoz. he wanna watch KBS World which need to put the 8 byte hex keys.
    Yes I also agree with u Loong , Topfield is more better than humax I think.
    Regards.
    " 李俊明 Born To Help People "
    canine consultant Expert
    instead of junping in and buying a stock standard HD receiver, you perhaps should have rearched a bit more and bought one with a PVR harddrive , like this .
    http://cgi.ebay.com.au/TOPFIELD-TF70...QQcmdZViewItem
    regards from OZ bassett
    THAILAND
    Default TOPFIELD HD models ...MPEG 4 OR NOT !!
    See the problem Brand new model and first item in spec says :
    "MPEG-2 HD,SD Digital and fully DVB compliant "
    Where's the mention of MPEG 4
    The good news came this morning from Topfield . See their email below :
    "Recording capability will be available on every TF7700HSCI.
    Regards,
    Hoze Li
    Marketing Team
    TOPFIELD "
    THAILAND
    Default Topfield Enigma
    SOLUTION FOUND
    Topfield HD receivers NEVER refers to MPEG 4. in their spec and that is /was very worrying to many as MPEG 2 is also used for HD .
    Why ? Because there are various versions.
    Topfield says instead "compatible with H264."
    H264 is the current version of MPEG 4.
    SO NOW WE KNOW
    H264 is used to compress the video data stream to almost HALF of mpeg2 data stream without loss in quality. there are a LOT of mpeg4 variants out there, but so far H264 (which is also known as mpeg4 avc or mpeg4 part 10 (maybe there will be part 12 etc, lol) is the best so far.
