Page 1 of 4 123 ... LastLast
Results 1 to 15 of 59
    Jan 2008
    Default newbie need help
    i am newbie. i have a dynasat silverbox 2 (made in korea) couple with 6ft dish. 2 check the current version of software on my box is during start up of the box? it written there l225. do i need to flash is with l377? actually wats the need of upgrading the software?
    previously i use it to view measat astro channels few years back and 2day i fix the dynasat back but cant view the measat satellite. its having good signal and response but the channels are all black. wat i need to do in order to watch the astro on measat? i noe its a pay tv and need card 2 watch it. can i watch it 4 free using dynsat? or dynsat is used to watch free air channels only?
    May 2007
    Down the road
    I think right now you can only watch Dream TV on Agila KU on your Dynasat box for free. For Measat Astro channels C-band you will need a server, it has been so for quite some time now. If you have a 6ft. Dynasat dish you probably have both KU and C-band LNB's in it. So set it on Agila KU, if you cant get a picture go to http://www.rdi-board.com/showthread.php?t=2232
    start from the last page and search for the keys for Dream TV
    you will have to go back a few pages to find them cause they haven't been changed for quite a few days, find the most recent ones and put them in the box. Dream TV is quite similar to Astro.
    The latest software in the box will update your Satellite list and channels(I think). There are many more knowledgeable members here than myself whom I hope can help you out.Should you not know how to enter the keys, start another thread, and I'll guide you through it.
    21.95° N 97.06° E
    Quote Originally Posted by guess View Post
    Before u do anything to ur receiver be aware that ur receiver hasn't protection chip and u can't load any higher version than L225. Only this versions will work for ur box L201 and L314 . If u want to upgrade ur receiver curiously then u need to install protection chip.but just remember , for Astro non version won't work for ur box.But u can watch Dream Tv at 146E with manually putting the keys into ur box as bro.Mellow said.
    Regards.
    " 李俊明 Born To Help People "
    Jan 2008
    so wats the latest software i can load in my dynasat silverbox 2 receiver?
    the current software i found is l377 on the net. What is protection chip?
    can i just flash it without the protection chip?
    if i dun1 to upgrade it m i still able to view the dream tv?
    May 2007
    Down the road
    Don't know about the software part. You should be able to view Dream TV though set your receiver on Agila KU. Then push on menu button , go to Installation, next menu go down to Input Code, Next menu go down to Nagravision1, push OK again and put in the keys in 4E01 00 and 4E01 01.
    Look at the PM I send you. Good luck.
    Jan 2008
    Regards.
    any software till now also unable 2 view astro on measat a? can u send me L314 software. my email address is [email protected]
    i saw yur previous post and still dun understand au for dreamtv. if software din support au for dreamtv so wat will happen?
    May 2007
    Down the road
    Just follow the steps above after setting the receiver to Agilla KU, then you can watch TV. If the receiver worked 2 yrs ago it should still work for Dream as long as you have a KU LNB. You will soon find out after putting in the keys. Don't forget to push Apply after entering Keys, then esc ( escape) to get out of the menu.You will have to do that for each of the 2 sets of Keys. Then it will work if you have a KU LNB, and you will be able to watch TV, how are you going to change software if you cant do that. It either accepts the Keys or it wont, nothing else will happen.
    Jan 2008
    Quote Originally Posted by mellow View Post
    brother 4 agila i just have the green signal onli le.. dun hav the red 1. what does it mean then? do i need to reposition my dish?
    21.95° N 97.06° E
    First I wanna suggest u to upgrade ur receiver with L367 which has update channels and then downgrade to L201. And then try it u can get the signal or not.
    Regards.
    Jan 2008
    Regards.
    bro can u send me L201 and L314 software? my email address is [email protected] or can u upload it here?
    21.95° N 97.06° E
    Yes brother , I'll upload it here.
    Regards.
    Jan 2008
    Regards.
    wat other satellite m i able 2 view in thailand? what are the free channels and pay tv m i able 2 watch?
    Jan 2008
    hey bro yan ying just now i upgrade yur L367 on my silverbox 2 but then after awhile while watching the dynasat box write err and screen go blank then restart by itself. Wats the problem? plz help me
    21.95° N 97.06° E
    I've already told u that u need the protection chip when u upgrade ur receiver to higher 246 version.No problem , downgrade ur version to L201 or L 314.
    Regards.
    Jan 2008
    Regards.
    bro can u send me the software L201 and L314 to my mailbox?
    my address is [email protected]
