Results 1 to 11 of 11
    aimal
    Default plz help about asiasat 2s and intelsat 10
    i have two dishes with one receiver through which i am watching asiasat 3s and intelsat 10.
    dishes size are 4feet solid.i want to watch waqttv on asiasat 2s and express new and ARY ONEWORLD on intelsat 10. what can i do?
    Jul 2007
    this is not posibal.
    You need card sharing Chack This
    http://cardsharing.freetzi.com/
    [email protected]
    aimal
    why it is not possible?
    Mar 2007
    Dear Aimal,
    The 4-feet Dish which is directed to ASIASAT-3S must be replaced
    with a 6-feet Dish. Prime focus this 6-ft for ASIASAT-2 and install
    a 2nd offset LNBF on same Dish for Asiasat-3S.
    You could also pick up either NSS-6 or INSAT-4B Kuband, by off-seeting
    another Ku LNBF.
    Ref ARY Channels, you already have a Dish directed at INTELSAT-10.
    So download on 3863 H 19850 for ARY Channels. What the Problem ?
    ( I presume you talkin about the FTA Channels )
    Regards,
    Kamaldeen.
    Jul 2007
    Dish Size Is 4 Fit Not Posibal ,
    [email protected]
    aimal
    can i watch express new on INTELSAT-10 with the help of 4 feet solid dish.
    hong kong
    Quote Originally Posted by aimal View Post
    yes you can watch express new on INTELSAT-10 with
    4 feet solid dish
    use pbi lnb it,s can work but ary pakg can,t 4 feet solid dish otheres pakg also multi choice can be watch
    aimal
    use pbi lnb.what its mean.
    Mar 2007
    [/QUOTE]
    Hi,
    For off-setting purposes for C-Band, 4-ft is too small.
    You may off-set 1 or 2 additiopnal Ku-Band LNBFs on the 4-feet.
    But for C-band, I minimum size of 6-ft is recommended.
    Try dispose your 4-ft and replace with a 6-ft:
    You'll be benefitted with ASIA2, ASIA3S, and INSAT4B and/or NSS6
    Ku channels.
    RGDS/HMK.
    aimal
    aimal
    Default help about LNB
    What is the meaning of pbi lnb?
