Results 1 to 15 of 17
    Nov 2005
    Doha - Qatar (but Italian)
    Arrow SKY*ITA decoder and card used overseas
    Hi guys
    Let me start wishing you all a great and prosperous 2008.
    While on vacation in Italy I subscribed to sky*Italy. They gave me a decoder Amstrad and card. I activated them in Italy succesfully, using another subscriber dish.
    Now, arrived in Qatar and... big disappointment: It does not work.
    I have a single cable coming down from my roof, carrying 4 different dish cables
    - Hotbird (sky broadcast is in here)
    - nilesat
    - eutelsat W3
    - turksat
    With my Starsat receiver I can see the list of Sky* channels, but of course I can not watch them! So I receive Sky* channels for sure!
    ...BUT the sky* Amstrad receiver keep saying NO SIGNAL
    Playing with the FEW settings available to the user (the receiver is really customized) I set up the LNB on 10750 (before it was on "universal").
    Now I have:
    Signal: the two bars (signal and quality) are both at half scale... not bad I guess.
    LOCK: it stays a little while on locked, then is switches on unlocked.
    Network ID: 006e
    Transport Stream 0013.
    If I go back to the TV, still "no signal from the dish" on the screen... no SKY*Italy
    Anybody here can help with some good suggestions?
    It is funny, I waited so much for some TV in my language while working overseas, and once I subscribed (2 years after thinking about if doing it or not) I can't watch it!
    Thank you for your attention, waiting for your help and insights!
    Happpy New Year!
    reset the receiver and choose inthe antenna setting single lnb
    Nov 2005
    Hi Dreamboy70
    Thank you.
    I did it but not working.
    Someone in here said that connecting DIRECTLY the dish/LNB to the receiver (in this moment the 4 dishes are coming downstairs with a single cable) I would solve the problem.
    Does it make any sense?
    Thank you and happy new Year!
    put dual lnb on the hotbird dish , this will solve the problem
    ciao
    Jul 2006
    Delete the satellites from set up & keep only the satellite for sky & then give the correct lnb specifications & scan.
    Manually assign diseq & scan.
    It worked for me with a similar problem.
    Nov 2005
    Dreamboy70
    Thank you, I will try (so far I never found in Qatar a dual LNB).
    EDITED: Bravo Fabio ... some times ago I bought in Italy 2 Universal Monoblock Dualfeed LNBf (emme esse 0.5 db noise figure) and never used them. Now I can mount one and try what Dreamboy70 suggested!
    In Qatar I would never find it because this is sold in Italy for catching Astra+Hotbird. Here it does not have a sense, because to receive Astra you need a dish min mt. 1.80 and stores are not ALLOWED selling such "big" dishes!
    Dom06
    This customized receiver does not allow these user operations (to select DISEQc, deleting satellites...it comes already all set up for Eutelsat or Eutelsat + Astra).
    Incredible uh?
    Tomorrow I will TRY to find cable and connectors to connect the dish/lnb directly to the amstrad sky receiver...
    THANK YOU GUYS, I really appreciate!
    Apr 2004
    Quote Originally Posted by Dohasat View Post
    Incredible uh?
    As your receiver does not allow diseqc settings you have two choices:
    1. As you have pointed out, you can run an additional direct cable from the lnb or,
    2. Since you have another receiver (your Starsat) that does have diseqc, you can use that receiver to select the LNB you want. Check that you receive the signal on the Starsat and leave it on a channel from the sky package. Feed the Amstrad from the LNB out (loop through) on the Starsat. Now the Amstrad will get the signal. This setup is a bit cumbersome as you will have to rely on your other receiver as well, but it will cetainly save you running an extra cable.
    Don't Stop......Keep Learning!
    THAILAND
    Dreamboy70
    Dom06
    Incredible uh?
    I.80M DISH.?....THATS SMALL BY DUBAI STANDARDS AND CHEAP ALSO QR/AED 100 ! WHY NOT POP OVER TO DUBAI AND BUY YOURSELF A 2.4 OR 3.6 M DISH....DIRT CHEAP THERE
    Nov 2005
    C-Band
    Can I tie the dish on the Top of the airplane to carry it in Doha
    I know my friend, here we are 10 years back if compared with Dubai....
    And remember... the big dishes are not for sale here because NOT ALLOWED!
    You need a special license/permission (better to give up).
    Think that I have the Extra license amateur (released by FCC - USA - New York) and even with this license I did not have the permission to take here my wonderfull receiver Icom IC-R8500!
    Tomorrow or after tomorrow I will try to do what suggested by Cruiser!
    Thank you Cruiser! Thank you to you all guys... let's see if we will win (solving this case) or not!
    Regards
    Nov 2005
    Dear Friends
    I connected a monoblock double LNB to the dish. This is the tipical LNB used in Italy to catch Astra + Hotbitd. I left Astra input empty.
    I tried this LNB before with my Starsat receiver and I was watching Hotbird Free channels perfectly, great signal!
    Then I used a brand new cable to connect the Hotbird dedicated dish and LNB to the Amstrad*SKY*Italy receiver.
    Settings: 1 LNB pow. supply ON, 10750 or uviversal
    Signal is very high, almost at the max. Quality more than half scale.
    ID 00b0 and Transport Stream 2e18 (I think the Network ID should be 0800?).
    and NO picture, NO Sky*Ita.
    Setting 2 LNB (Hotbird + Astra) the Network ID become 013e and Transport Stream 3138 and NO picture, NO SKY*Ita as well!
    I can't believe seeing SKY* from here is so hard and lmost an impossible rebus!
    I hope someone can help me once we tried this too but without success.
    Thank you
    Regards
    Nov 2005
    Cruiser
    I discovered something important.
    With the receiver in loop (dish to starsat receiver and loop with sky*italy* receiver) I can see the FTA channels.
    If I go on some paytv channels the receiver says "no signal from the dish".
    I will wait for your insights, thank you!
    Oct 2002
    THINK!
    Thumbs up Sky italia OOk in M.E.
    My friend from Middle East got Sky Italia on DB, 90 cn dish & Universal lnb.
    use direct, single lnb to your sky receiver.
    Nov 2005
    I want to start saying to you all a big thank you for your support guys!
    Conclusion of the nightmare
    To make it short I will tellyou guys the final working configuration and what was surely not working:
    To watch Sky*Ita* (with a regular smartcard) you need.
    - to use a dedicated dish,
    - LNB: if you do not have a single one, use the double moniblock. U can leave Astra input unused.
    - Set single from the receiver.
    - LNB: Universal - pow.supply: ON - Tone: off.
    Network ID: in mi case fbff and Transport Stream 16a8
    Connecting receivers in loop with a coaxial cable (output of the first receiver going in the input of the second one) does NOT make you watch paid channels, but only FTA.
    Blue screen: to reset your receiver unplug it from the 110/220 and disconnect the coax cable. PLUG the coax cable and the 110/220 after 30 sec and push the-sky* button after 30 more sec. (I was told about it by the customer service).
    Put the receiver on channel 110.
    Now everything is working smoothly. From Qatar with mt. 1.20 dish and dual LNB monoblock emme esse 0.5 noise figure the signal is almost at the max.
    Thank you to you all guys, I hope this thread with all the symptom descriptions will help some other guys facing similar problems.
    See you soon, Ciao
    THAILAND
    See you soon, Ciao
    PLEASE SEE MY PM !
