    Senior Member Teacher
    May 2005
    On The Move
    Default NEED HELP FOR TOSHIBA A60 SATELLITE LAPTOP
    Dear RDI friends,
    Recently i have bought a TOSHIBA A60 SATELLITE LAPTOP which dosen't have a COMPORT only USB.
    What additional equipment for COMPORT i need to buy to use my LAPTOP for upgrading receivers..?
    As i have seen some USB>>>COMPORT converter in the market but i want to make sure which one is the best.
    INTEL PENTIUM 4/2.8/60GB/WIRELESS SUPER G 802.11
    any comments...?
    Thanks
    ART IS TO COMMUNICATE.....
    you can buy any usb-serial comport adapter as most of them are using the prolific chips, then use the supplied driver or download one from the manufacturer site. i am personally using a Toshiba, with prolific usb-serial adapter, pl2303 drivers i think for xp.
    May 2005
    On The Move
    Default Toshiba Laptop
    @boknoy
    I am using windows xp also,so what do u think that kind of adapter will work for upgrading software to receivers...?
    can u pls tell what should i need to buy i want the perfect one which is suitable for my laptop it dosen't matter how expensive it is.
    Thanks
    as i said, ANY usb serial adapter should work, and the most common chips they use is the one from prolific company.
    May 2005
    On The Move
    Thanks for ur information.
    i will find out and will check.
    Have fun
  1. Replies: 0
    Last Post: 27th June 2006, 16:53
  2. laptop p2
    By str-evo in forum Shop
    Last Post: 5th June 2006, 07:19
  3. Vind Laptop Toshiba PIII.Vindut
    By dun in forum Shop
    Last Post: 23rd March 2006, 22:31
  4. setari convergenta retroproiector CRT Toshiba
    By cosmin_v in forum DVD - DIVX - HIFI
    Last Post: 7th May 2005, 12:02
