Results 1 to 6 of 6
    Oct 2006
    Romania, Sighisoara
    Question Help, Am uitat codul telefonului
    Am uitat codul telefonului Sagem myx5-2.
    Imei 35305600434164 - 5
    Ma poate ajuta cineva?
    Nebunul de la butoane Expert
    Diemrich
    http://gsmhosting.com/vbb/forumdisplay.php?f=42
    poate te ajuta informatiile de aici.
    Sep 2004
    Quote Originally Posted by Laur_24 View Post
    Mergi la un service care se ocupa de tel. nu ai nici o sansa sa-l deblochezi dupa IMEI
    Dec 2006
    Ca fapt divers, o parte din Nokiile mai vechi se pot debloca si printr-un cod generat de IMEI ... mai naspa e daca bagi codul gresit de 5 ori pentru ca aceasta "portita" se inchide si ai nevoie de cablu pentru deblocare
    FLEX-IBIL Expert
    Mall d'Ovax
    http://en.soft4gsm.com/Main+Software...lock+Software/
    Sagem PHP encrypter
    steluta diez 06 diez si afli datele necesare pentru a-l decoda.
    Phone Info
    MODEL: Unknown (please send IMEI and phone model to [email protected])
    IMEI: 365003414465--
    Lock and unlock codes
    Code for level 01: 18594566-83 (new field 251: 6ed50eab)
    Code for level 05: 17856427-68 (new field 251: 6a6ebf10)
    Code for level 41: 07768811-55 (new field 251: 2e4e4403)
    Code for level 00: 18781706-60 (new field 251: 6ff29c24) - unlock code
    Code for level 40: 07940144-80 (new field 251: 2f53b310) - unlock code
    100% working unlock
    All locks levels set to 00 or no restrictions
    Field 191 and 251: 6FF29C24 (00 + 3 bytes checksum)
    Field 252: 6F43607A9131ABADC448BBB2063534 (0000000000000000000000 + 4 bytes checksum)
    Field 253: 6F43607A9131ABAD676B98B2 (0000000000000000 + 4 bytes checksum)
    Field 5709: 9B5A0841 (FF + 3 bytes checksum)
    Little help
    Mode Crypt and Decrypt
    Insert Field 0 (IMEI), ID, select hash table, select how many bytes are checksums and insert data. In field 0, ID and data can be spaces between bytes. You can crypt/decrypt few values in one step - in field DATA insert few plain values separated by ",". When you decrypting few values in one step all must have the same checksum length.
    Mode Crypt special and Decrypt special
    Insert Field 0 (IMEI), ID, select hash table, select how many bytes are checksums and insert data. In field 0, ID and data can be spaces between bytes. When you decrypting few values in one step all must have the same checksum length.
    Mode Protected fields list (5250)
    This is for beginners. Fill Field 0, ID, select hash and insert your field 5250. Script return list of protected fields.
    Mode Rebuild protected fields list 5250
    Use when you want change list of fields which are protected by checksum. Fill Field 0, ID and select hash. In input DATA insert numbers of protected fields separated by "," (example: 16128,16129,16140,16141,16178,185,227,268,5120,995 ). Script return your new field 5250 value.
    Mode Unlock and lock
    Fill Field 0, ID and select hash in form. Script show you codes for locking and unlocking your phone.
    Mode WAPlock (field 5709)
    Fill Field 0, ID and select hash in form. Script return list of usable values for field 5709.
    Mode Most used values
    Fill values as in Unlocking mode. Script return most used values for few important fields.
    Mode Short id to long format
    Classic convert from Short ID to long ID. Here is maybe little error and all ids must not be right. Fill only phone ID.
    Mode Hotline menu code
    Script generate code for enter to hotline menu in Sagem phones 30xx and 9xx. Insert Field 0 only.
    Mode Detect hash - crypt
    Fill field 0, ID, how many bytes are checksum and insert data crypted with normal crypt. Script try all hash tables and display which is correct.
    Mode Detect hash - special crypt
    Fill field 0, ID, how many bytes are checksum and insert data crypted with special crypt (typically field 5709). Script try all hash tables and display which is correct.
    Mode Fields value compare
    This is for lazy guys. Fill input DATA with two strings separated by "," (ideal for longer fields as 16140). Script control length and compare these strings and return if are the same or on which position is first difference.Visitors: 12835
    Author: tm at the dot cz
    LABOR OMNIA VINCIT IMPROBUS (lat.) munca stăruitoare învinge totul – Vergiliu, „Georgica”
    NON OMNIA POSSUMUS OMNES (lat.) nu toți putem toate – Vergiliu, „Bucolica”, VIII, 63.
    Pentru prost, umorul e o formă indivizibilă de insultă, e ceva care-l vizează personal. Umorul mușcă, înțeapă, provoacă, sfidează, și face toate astea involuntar, uitîndu-și mereu foloasele, așa cum procedează electricitatea. Bușcu dixit.
    FLEX-IBIL Expert
    Mall d'Ovax
    sau incearca>
    <a href="http://www.filefactory.com/file/8f5d50">sagem MYxxxx.exe</a><br />
