    Sep 2004
    Default Strong 6125 HELP !
    Salutare !
    Am un receiver Strong SRT 6125 la care am vrut sa ii pun un alt patch + key noi. Orice i-as face de atunci numai mesajul asta imi apare :
    Cine ma poate ajuta sa scap de aceasta problema ?
    Am incercat de asemenea sa ii schimb firmware-ul dar nu am reusit cu nici un loader
    Rog HELP !
    CristianTM.
    Member Teacher
    Cred ca ai instalat o versiune de patch pentru un alt medel de receptor.
    Trebuie sa o iei de la capat cu instalarea (BootLoader.exe ApplicationLoader.exe PatchLoader.exe) Nu este suficient sa instalezi patch! Mai multe lamuriri gasesti aici:http://www.frocus.net/main.php?lng=en&rzd=statii&pag=7 si softul necesar aici:http://upl.frocus.net/index.php?lng=en&p=4 Am avut si eu o situatie de acest fel, dar nu mai stiu ce mesaj aveam pe ecran si am rezolvat-o incepand cu instalarea bootloaderului si apoi celelalte. Nu uita sa tii apasat ch down la incarcarea bootloaderului.
    Succes
    Member Teacher
    Ai aici ceva instructiuni in engleza. Sper sa fie de folos.
    CI_patch update procedure:
    1. Connect receiver to the pc , hold down channel down button on the receiver front panel , and connect receiver to the mains. Now on the TV the following display:
    2. Start Boot Replacer 1.0.3.exe , start procedure with the connect button .
    After boot replaced the following must displayed on the screen:
    3. Start eWinloader.1.1.2c.exe select the connect icon
    4. Select upload data from PC to STB icon
    5.Browse the WeaksoftFTA 2p2 18.09.2005 blue.urt file start update
    If update successful the following displayed on the TV screen:
    5. Switch receiver to software update mode :step 1
    6. Start Weaksoft1.5.0.exe , select Upload patch code icon , browse the srt6xxx Path file and start the update.
    7. Start receiver in software update mode , step1 : Start Weaksoft1.5.0.exe select file menu point ,open 6xxx keys .bin file, update the changed keys then select upload keytable icon.
    Now update procedure finished.
    Now you can use the hidden menu in the receiver :
    Enter menu ---- install --- system setup --- system information (select this menupoint)
    Push : 4-2-2-5 buttons , receiver open hidden menu.
    Channel editor works same as eIRD editor.
    For channel download from receiver use CH DOWN button on front panel
    __________________
    Sep 2004
    Multumesc de sfaturi. S-a rezolvat pana la urma. Nu stiu de ce dar cheile le-a recunoscut receiver-ul numai cand le-am incarcat cu WeakSoft 1.6.0 nu cu 1.8.0 !
    Bafta la toata lumea.
    CristianTM.
    ALBA
    va rog sa imi spuneti cu ce versiune de URT,patch si key se poate vedea premiere.
    DM 500S-KLASSE
    Dec 2007
    Unhappy help
    Salutari,, in speranta ca ma ajuta cineva am scris acest mes, Am un strong 6125 si nu pot in nici intrun fel sa il conectez cu pc-ul,, receptorul pur si simplu nu raspunde, am legat cablu la serial am apasat butonul CH DOWN, si degeaba, nu vrea cu nici un program. Parerea mea este ca este problema cu bootloader-ul, este vers 4.6.7ps.
    PatchLoader
    ApplicationLoader
    BootLoader
    Weaksoft 1.8.0
    etc..
    eroarea este urmatoarea
    <========== Error ( -4 ) ==========>
    Problem : No response from TARGET
    Solution: Make sure Target Loader is running properly
    Connect your Serial Cabel Properly
    Port Settings are not Correct
    Retransmit UART File after Restarting the TARGET
    daca scot receiverul din priza apas down in timp ce programul ruleaza apare urm chestie
    | Loader Configuration Settings |
    Loader Software Version = 4.6.7ps (HW MjrVer-4)
    Loader Configured for 1 x 16 Mbit flash
    Target Flash MCode = 0x 200020
    Target Flash DCode = 0x22C422C4
    Loader supports Box To Box Copy
    Loader allows same version to download
    Download from UART demanded ...
    dupa cateva secunde apare dinou prima erroare... Error ( -4 )....
    ce e de facut
    Suceava-Germania
    Default srt 6125
    Salut , ai cablu null modem sau serial ?,
    Dec 2007
    Default Salutari.. Am nevoie de un Flash dump Jtag cu patch nou si soft nou la un SRT6125
