    Sep 2007
    Default DCC only expert can help me
    I am using cccam on dm 500 s I use DCC to config it. every thing fine. but when I try to connect dm 500 from my work using DCC. I enter my home ip for dm telnet get connected but not ftp. i have tried both my home router and work router always same. dcc give message like illagel port command. any help?
    Quote Originally Posted by thamon View Post
    have u allowed permissions through the routers firewalls?
    cheers,,,dave
    Sep 2007
    witch port permissions can you explain please
    Apr 2004
    In order to communicate with your DM500 over the Internet (ie outside your home network) you will require to configure your Internet router to point to your DM500 for the respective ports. On a home router this is usually done through port forwarding. As you know services operate on different ports, you will have to forward the ports for every service you want to communicate with your DM from the Internet. The standard port numbers are: Telnet: 23, FTP: 21, http: 80 and so on.
    I'm sure you know how to configure your router so I won't go into that. Since you say Telnet is working, port 23 is correctly forwarded to the IP of your DM. For FTP, you need to forward port 21.
    Don't Stop......Keep Learning!
