Results 1 to 15 of 21
    philippines
    Default Latest Firmware for STARSAT receivers
    To all STARSAT users,
    You can upgrade your receivers with the latest firmwares....go to
    http://www.satsw.net/
    somewhere in a middle of nowhere
    or try this www.satdw.com .usually sw's comes here first
    DREAMBOX 500S
    STARSAT 550D SUPER
    DISH 140CM PARABOLE
    LNB GRUNDIG
    lebanon-beirut
    can anyone know the difference between this new firmware and the older firmware because until now the older software it open multivision. anyone know if this new firmware can open multivision in viaccess 2.5
    philippines
    Quote Originally Posted by wissam_saade
    You can ask your query in http://www.satsw.net/forum
    Sep 2004
    Default Latest software for starsat have problem please help
    Last week i download the new software from the site and upgrade my starsat 150d plus but unfortunately when i upgrade the receiver i lost every data in the key section. When i presee 1234 and reach the key area i can see no data found screen only. Please help me to restore the keys and able to watch multivision and all other channels
    eagerly waiting for your help
    philippines
    Default Re: Latest software for starsat have problem please help
    Quote Originally Posted by valiyana
    First, you have to clean the flash memory of the receiver. Then upgrade with the latest firmware. Last, download the Jun_20_key_bin file to your receiver.
    Aug 2003
    If you have upgraded the box to the latest update software, try without cleaning the flash memory just download the latest key file. I hope it will work.
    to clean or not to clean.... that is the question.
    Nov 2003
    United Arab Emirates
    no need to clean just put new keys and thats all
    philippines
    Dhongkoy&dodi,
    I had the same experience as with valiyana with SRX-150D, an advice with the other m8s from the other forum, is I have to clean first the flash memory. So I did, the result was my STB work fine and all the keys were re-stored.
    Sep 2004
    Default HI ALL MASTERS
    OK,
    I WILL TRY TO PUT THE KEYS MANUALLY FOR TPS BUT STILL ITS NOT OPEN AND ALSO NOW I AM NOT ABLE TO WATCH EUROSPORTS OR ANYTHING EXCEPT POLSAT.
    IF I WANT TO CLEAN THE FLASH MEMORY WHAT IS THE PROCEDURE AND HOW I WILL DO IT , HOW I WILL GET THAT FILE. IT WILL DAMAGE THE RECEIVER OR NOT , IS THERE ANY RISK BECAUSE IDONT WANT TO DAMAGE MY RECEIVER . PLEASE HELP ME AS SOON AS POSSIBLE.
    philippines
    Default Re: HI ALL MASTERS
    OK,
    go to http://www.satsw.net/. There is a learning feature on how to upgrade your STB.
    bombastik
    Default emupgrade starsat 1500d super mkii
    my sister bougth this reciever from ksa,how will i upgrade the software for this reciever, icant acces the key code menu, is this reciever auto update on nagravision?how can i download the flash file 1500d super mkll bigtuner.thanks
    philippines
    Default Re: emupgrade starsat 1500d super mkii
    Quote Originally Posted by bombastik
    as I said there's a learning lesson in satsw.net. 1500D is not autoupdate. You can upgrade the firmware but then you have to update the key manually once the changes of the provider is regularly.
    Saudi Arabia #53
    Do Starsat 550 AU's Dream from Agila2?
    Regards
  1. The Latest update for SKY X Receivers ??
    By waiel3000 in forum RDI - English
    Last Post: 19th October 2008, 18:07
  2. Which are the best & latest receivers for inputting AES
    By imtiaz54 in forum RDI - English
    Last Post: 24th October 2006, 20:15
  3. firmware nou pentru galaxis receivers
    By adant in forum SD Receivers
    Last Post: 11th January 2006, 18:01
  4. STARSAT Latest FIRMWARE POLSAT AU
    By carlomaderazo in forum RDI - English
    Last Post: 16th July 2005, 19:52
  5. LATEST FIRMWARE FOR FORTECSTAR5100PLUS
    By gepeto in forum SD Receivers
    Last Post: 11th January 2005, 11:03
