    Jun 2007
    Default Procedure to load CCCam on DreamBox DM 500 for Client ?
    Hi All,
    Friends please help me in loading CCcam on my Dreambox DM 500...
    Please tell me the procedure to do this.
    Thanks in Advance.
    Regards,
    BLR
    alanpaladka
    You told me in PM that you have already loaded CCcam via Bluepanel. So I thought you solved the problem. But now you are telling different story. Why are you like this? Even I'm not a expert in Dreambox. I saw Dreambox just two months before. Still, I hadn't found it difficult to install CCcam. There are loads of tutorials in many forums. Even MaldivianDigital has lot of tutorials. You can refer rdi-dreambox.com too. It has many PDF tutorials. Instead of reading them, you are simply asking questions like INFANTS.
    Let me give you some idea. Press Blue Button. Then Press OK on Addons. Then Press OK on Downloads(Gemini Server). Then press OK on CAMS. Then you will see the following screen :
    Just click OK on CCcam 2.0.4. You are done!
    Jun 2007
    HI Alan,
    Yes I have loaded CCCAM 2.4 after loading this
    pls see the Attached Pciture ...what else I have to do for TATASKY ...
    alanpaladka
    Now you have to wait for C line. Its format is like this.
    C: serveraddress port username password
