    Sep 2006
    Default using diseqc in a SkyStar 2 and using SkyStar 2 in a 64 bit pc?
    Hello to all!
    I have a SkyStar 2 installed in a pc. My dish has one lnb but now I am thinking to buy another lnb and a diseqc. But before buying it I am wondering, will I have any problems installing and making use of the second lnb? I want to position them at Astra 19.2 and HotBird 13. Should I have something in mind before getting them?
    And I, also, might get a new pc 64 bit. My actual pc is x86. Does it change anything in using SkyStar 2 with an X64 platform? I use s2emu and vPlug with ProgDVB and DvbViewer.
    I would really appreciate an answer as soon as possible
    Thanks!
    Dec 2007
    Smile
    Ermond
    i too have a sky star 2 card in my PC with 64 bit intelcore2 duo processor and i am not facing any problems just get the latest drivers from technisat.as far as diseqc switch is concerned yes there are some problems i have two dishes pointing at hot bird 13 degree (ku band) and Intelsat 7/10 (c-band) i am getting all the channels on Intelsat but facing problem getting all the channels on hot bird. its wise that u buy a good diseqc switch and don't go for those cheap Chinese ones available in the market then you wouldn't be facing problems.
    Sep 2006
    Thanks for your answer WINGLESS_ANGEL
    Really appreciate it!
    Dec 2007
    Smile
    any time if u want to ask more willing to share information
    Sep 2006
    Hi WINGLESS_ANGEL!
    I installed it and it worked quite well. I bought a good disecq (at least I think) according to your advice. It works well although I have the impression that I lost something from the signal but I thinks this is normal.
    Thanks again!
