Results 1 to 15 of 16
    Jul 2006
    Default INSAT4B & NSS6 on same dish
    HI Friends,
    I have an offset 90 cm Ku band dish, aimed at NSS6 @95 degree E.
    I have a dual ku band lnb & if installed will I be able to catch INSAT 4B @ 93.5 degree E & NSS6
    Will appreciate some comments before I start on changing the lnb.
    My location Bangalore
    Chennai, India
    Smile
    Yes you can get both with one lnb.
    Is it possible to receive both insat 4B and NSS6 on the same 6-feet dish in Kuwait?
    South India
    Quote Originally Posted by dom06 View Post
    HI Friends,
    Yes.. it is easy to get it as you want it in bangalore..
    but just a point... why u need dual lnb ? do u want to connect to 2 STB?
    You cannot teach a man anything; you can only help him find it within himself.
    alanpaladka
    Quote Originally Posted by frony View Post
    No. Signal level of both satellites will become weak at Kuwait. So it isn't possible.
    do u mean 1 lnb,,or 1 dish
    cheers,,,dave
    South India
    we can get with 1 lnb and 1 dish.
    alanpaladka
    One Dish & One LNB.
    Quote Originally Posted by alanpaladka View Post
    One Dish & One LNB.
    thats cool!,,thnx for clarifying
    cheers,,,dave
    Hindustan
    Thumbs up Same location
    FYI, You can point to any one of the satellites (NSS6 OR INSAT4B) and you can get all the channels from both the satellites with ur Dish and LNBF (1 dish + 1 lnbf).
    Just enter the TPs into ur STB/DVB-S Device and scan.
    It will list out all the channels of both NSS6 & INSAT4B.
    currently there are 9+5 TPs from NSS6 & INSAT4B respectively.
    And the number of total scaned channels may be arround 230+ (I donot remeber exactly now)
    So enjoy .......
    Technology Makes You Live
    Jul 2006
    Friends,
    Thank you for your feed back.
    In the Gulf area you need 2 lnb & 2 dish to get NSS6 & INSAT4B.
    I was thinking maybe in India you could get both with dual lnb, but its good to know that its possible on a single lnb.
    Actually I already got INSAT4B TPs with the dish focussed to NSS6.
    (Grrrrrr but very difficult to add satellite with my DM 500s with Gemini, just learning)
    alanpaladka
    Yes. Some satellites may be missing in your DM. In that case, you should use a updated satellites.xml file.
    You will learn as the time progresses...
    Default one lnb
    u can get it with one lnb in karachi pakisan
    alanpaladka
    Quote Originally Posted by scrombi View Post
    But you cannot get in Gulf like that.
    is the abilty to do this reliant on being a certain distance from the sat?,,,in my logic of it,one would think that if the receiving dish is located closer to the sat ,,that the visable spread of the 2 signals would be wider ,compared to being at a further distance away and the 2 signals appearing to be in a narrower transmission plane?please correct me if this is wrong.
    are any members in thailand capable to do this,,or is it a phenomonon relevant to our indian brothers only?
    cheers,,,dave
