Results 1 to 15 of 22
    SATELLITE GURU Expert
    Default Dreamsoft for Emetabox BeSat and ATLANTA @SKY 1.4.4.0 Final
    Here is the latest final Dreamsoft file. Upload and enjoy many bug fixes.
    http://www.ucascity.com/forums/showt...7896#post17896
    Default POLSAT WORKING ON THIS DS?
    Is this DS latest as of today? As you know, POLSAT AU has stopped since yesterday. Is this version of Dreamsoft AU for POLSAT? Thanks for the info!
    Default Re: POLSAT WORKING ON THIS DS?
    Quote Originally Posted by faded comet
    yeah, the new Polsat RSA keys have been implemented. too bad for me, my usb-serial adapter stopped working so i cannot update anything on my receivers now.
    i hav got polsat and infosport working..that means am i using the latest DS right?
    bedjoker
    Quote Originally Posted by pokkiri
    You click Menu---System Information---there you see the date of your DS and compare it with the latest DS date posted in that link
    Sep 2004
    Default Dreamsot 1,4,4,0 final
    Hello friends,
    Hi guys i check and load s/w 1,4,4,0 final in my Metabox,its working fine except for polsat nagra,sometimes frezze and its power off if you change channel only in polsat nagra..but for emetabox no problem ,only small delay for the picture to come in polsat nagra if you changes channel,but over all working fine and tested by me...
    Go to code edit or key entry and do enter all zeros in viaccess.
    Then save and reboot your computer. This will flush all the codes and then the emetabox will reload all the keys and everything will work fine.
    Regards
    Sep 2004
    Default Code Edit
    Thanks Irdeto2Engineer,
    I will try that and i will give you info.polsat AU not working now on my emetabox..
    Default Re: Code Edit
    Quote Originally Posted by MIG_PILOT
    still working fine here, DS 1.4.4.0polsat fix file.
    Pakistan
    Default Hi
    Hi
    is it Danny's release or some one else .
    i m not intouch with it since some weeks due to my exams .
    even i have METABOX3 .. .
    take care u all
    Sep 2004
    Default S/W Metabox
    Hello Irdeto2Engineer and Friends,
    Is this the new s/w Dreamsoft 1,4,4,0 B1 Compiled June 9,2005 for Polsat AU?thanks.
    bedjoker
    Default Re: S/W Metabox
    Yes, it's polsat au; the DS 1.4.4.0 B1_polsat fix version
    Sep 2004
    Default S/W Metabox
    Thanks Bedjoker.
    Sep 2004
    Default S/W 1,4,4,0 B1 Polsat Fix
    Regards.
    Hello friends,
    I try this, now my stb metabox working fine,and also to my friend emetabox user Polsaat AU working fine.thanks irdeto2engineer and friends.
    brandon
    hello friends. I recently bought a receiver DSN 8300 As i imagine i can use this firmware on my receiver too ... right ?
    big thanks
  1. dreamsoft to metadream?
    By mosat in forum RDI - English
    Last Post: 6th May 2006, 21:23
  2. New Dreamsoft 1.4.4.5 Polsat and D+ AUTOUPDATE
    By system32 in forum RDI - English
    Last Post: 26th March 2006, 16:56
  3. Dreamsoft 1[1].4.4.1 D+ working BY DENNY
    Last Post: 4th January 2006, 18:18
  4. Dreamsoft 1.4.4.0 UPD 17.11.2005 Multivision OK
    Last Post: 18th November 2005, 02:26
  5. uploading dreamsoft to @sat 6910
    By bobbyb in forum RDI - English
    Last Post: 9th October 2005, 00:22
