    Pakistan
    Unhappy Twinhan DVB Card and scramblemed Ch
    goos day friends. i am new to dvb cards. i just bought one and installed on my pc. i have hotbird reception , and installed progdvb. can u guide me how to use softcams and keys to view scrambled channels on hotbird and other sats. i will greatfull for ur kind help .plzz
    Nov 2006
    Install VPLUG in progdvb and put softcam and run it.
    Pakistan
    Default Thank you
    Thanks for the help i did install vplug. i can see TPS Now .. but no polsat,.. where do i get the keys and where do i put them ?
    Polsat is down at the moment.
    pakistan
    polsat working fine with v.plug 2.0.1.0.just wait for two or three minutes on any polsat channels.and it will au.
    Dec 2007
    Default Really New, been searching and searching - help
    Hi there, I am really new at FTA. I have a twinhan 1020A PCI DVB card, what do I need to DL, and from where to get all the scrambled and locked chanels? Any and all help would be much appreciated as I have DL a bunch of stuff (installed wrong directories now) everytime I start either DVB Dreamer or ProgDVB they crash.
    Default dear
    yes,if you have DSL connection you can easily connect to gbox server and view large number of channels free
    raste
    Quote Originally Posted by Rossovich View Post
    1. www.progdvb.com dvbdream.de for your softwares
    2. install the latest vplug as advised (google is your friend)
    3. scan your satellite, and hopefully your softcam/emu supports the channel you wish to view.
    4. uninstall, remove the directories and start cleanly.
