Results 1 to 14 of 14
    Nov 2007
    Default Pansat 2700A neutilizat de un an - Help!
    Buna tuturor,
    Am vrut sa instalez noul boot b75, daca nu ma insel, am facut urmatoarele:
    1. Folosind: "X-87BL Loader v27.02 [X-87BL]" am "flash" "Boot_2700A(b75)_(07)0310"
    2. Din pacate am obtinut "nightrider"-ul
    3. Folosind "GTRom Loader v27.01 [pansat2700A]" am flash "Pansat 2700A_061217_116_api" original... a mers.
    4. Factory settings.
    5. Am facut 1. si 2. din nou dar tot "Nightrider" am...
    Ce fac gresit? Multumesc anticipat.
    Aug 2007
    Quote Originally Posted by dishguy View Post
    Buna tuturor,
    opresti receverul din spate iar cand ii dai drumul la prima liniuta dai drumul si la download, incearca sa bagi Pansat 2700A_070310_B75_120_api prima data si apoi binul la zi
    Nov 2007
    Asa am facut, cum a aparut prima liniuta am click "Download".
    Ce nu am facut este 2700A_070310_B75_120... unde post sa-l gasesc?
    Aug 2007
    Nov 2007
    Multumesc. Am sa incerc si postez rezultatul.
    Nov 2007
    Acuma observ, 2700A_070310_B75_120_api necesita boot b75. Nu?
    Scrooling B-75 nu pot sa obtin prin flah Boot_2700A(b75)_(07)0310, doar night rider!
    Nov 2007
    Mai clar astea sint instructiunile care le-am gasit acuma:
    1. b75 boot upgrade needed only one time for each receiver to make enough space for future software upgrade.
    2. Connect null modem cable between PC and receiver.
    3. Open new GTRom Loader v27.02(Pansat2700A B75). Old version v27.01 will not works.
    4. Click BIN File and open “Boot_2700A(b75)_(07)0310
    5. Turn the receiver power “ON” and click download and wait until Download Completed OK appears. Front LED will display moving b-7-5 left to right if upgraded succeeded.
    6. Open new bin file matching with b75 boot version (Any api version dated on or after Mar 10, 2007) and click download. Wait until “Download Completed OK appears. Front LED will display ON or any channel number after b-7-5 shows shortly if download succeeded.
    7. 2700A, 2700A(IR), 2700E all 3 models can be applied.
    M-am inpotmolit la faza marcata in rosu! Cum pot sa obtin b-75 ?
    Aug 2007
    poate ca nu tia intrat b-75 . incearca sa bagi cu v27.01 bin 116 cred ca era factory si apoi mai fa odata tot ce e scris mai sus pt b-75
    Nov 2007
    Am incercat si b75 nu intra! Sa te crucesti nu alta! Ce pot sa fac? Am pus inapoi 116 si merge. Pot pune orice file daca nu este b75. Numai boot b-75 nu!?
    Aug 2007
    da,dar nici o alta file nu o sati deschida ceva daca nu sunt b75, mai incearca ,dai siun factory setting si incearca din nou
    Sep 2007
    ..... Milky Way Galaxy
    Default ..tot ce ai nevoie pt. 2700A
    http://www.hostclip.com/dl/633e9dd7c...9846628fa05cb7 ..ai aici tot ce trebuie , eu personal am folosit ,
    Pub Member / Supporter
    Dec 2007
    Default [email protected]
    Buna tuturor,
    hy
    please i'm looking for fil bin for my pansat 2700 cloun
    please helppppppppppppp tks
    georges
    Dec 2007
    Quote Originally Posted by cerna View Post
    hy
    please i nid help .
    new fil bin pansat 2700
    after 28 novemmber 2007
    tks. georges
    Bătrîn fără minte Expert
    Dec 2002
    Calare pe măgar
    Quote Originally Posted by jeano View Post
    hy
    please i nid help .
    tks. georges
    numai atmega 256 si plasticu merg acum mai asteapta citeva zile pentru fta
