Results 1 to 15 of 25
    Aug 2007
    Default TataSky Card in Dreambox using CCcam
    Accessing TataSky card in Dreamox 500S using CCcam
    Go to TataSky STB and get your BOXID.
    01. Menu.
    02. Organiser.
    03. System Settings.
    04. System details.
    NDS number is the Box ID.
    In this example the boxid is "001054608546"
    Discard the "0" zeros in the begingin and also discard the last digit so it becomes
    105460854
    Now we need to convert this to Hexadecimal number.
    You can use the Windows Calculator or go to this web site
    Dec to Hex
    Put your boxid in the Decimal Field and press the button "Decimal to Hex"
    The Hexadecimal number is 6493476. Its 7 digit's but it needs to be 8 digits. so put a leading zero in it.
    So
    6493476
    Becomes
    06493476
    Install CCcam in your dreambox.
    Open the CCcam.cfg file which is in /var/etc/
    You will need to add line to it for boxid.
    Code:
    BOXKEY: /dev/sci0  06 49 34 76
    a space is needed between every two digits of the boxid.
    Thats it. copy this CCcam.cfg file back to your dreambox and put the card in slot.
    If you have dreambox with 2 slos then u can also use the second slot for it.
    The boxkey will then put like this
    Code:
    BOXKEY: /dev/sci1  06 49 34 76
    This is for slot number 2 ( or upper slot)
    alanpaladka
    Thanks Tahir for this wonderful tutorial. Much appreciated!
    piplan mianwali
    wonderfull work brother
    that is a precious post
    must be a sticky one
    dreambox 500s
    8feet motorized+three fixed on pas10+asia3+arabsat
    yes, really its a very easy and simple guide .......
    Oct 2007
    bhai will this
    number be blocked if i follow your method?
    ZAFARJOIA Teacher
    Aug 2004
    PAKISTAN
    Default tatasky card in dreambox
    Not Working Dear...?
    Jan 2007
    PAKISTAN
    Default Tatasky
    Hello To All,
    I Have Tried Cccam. Tatasky Card Is Not Working.
    My Card Is Locked And Is Not Working In Origional Box
    Now.
    Be Carefull All Friends
    Good Dreams
    ZAFARJOIA Teacher
    Aug 2004
    PAKISTAN
    Default tatasky card in dream box
    i am trying to open channels by your recomended method only three channels
    1- help
    2-promotional channel
    3- showcase promo are working
    these channels open also without any box id
    but the important channels are other channels which are not working.
    thanks
    SATELLITE GURU Expert
    Quote Originally Posted by ashraf_7002 View Post
    bhai will this
    This is from an original Tatasky decoder
    Oct 2007
    Quote Originally Posted by irdeto2engineer View Post
    i was wondering if i follow the method posted above will i be able to bypass that number
    alanpaladka
    bhai will this
    That number is coming from the original box of your DTH operator. Its not your VC number. So you don't have to worry about blacklisting.
    Aug 2007
    Quote Originally Posted by CABLE_NETWORK View Post
    Hello To All,
    Now.
    Good Dreams
    How did u card get blocked,
    It cant be becasue of wrong boxid, because the first card i got working was really a mess, i tried alot of combinition of boxid but none worked and non of them blocked the card.
    The boxid is only to get correct CW's from card, When the ECM's goes to card, the card responds by sending back CW's. But these CW's are encrypted. So the boxkey is needed for it to decrypt the CW's.
    ZAFARJOIA Teacher
    Aug 2004
    PAKISTAN
    Default .....virus Alert.............
    Dear Friends,
    I Have Tried The Backup IMMAGE In My Dm500s. After Downloading The Backup File
    My Box Is Dead .......
    Totally Dead..........
    Be Carefull .......................
    Be Carefull............................
    alanpaladka
    Quote Originally Posted by zafarjoia View Post
    Dear Friends,
    First of all, why you tried Backup image? Tahir had clearly written the steps. You could have tried those steps with the original Gemini image.
    Oct 2007
    Quote Originally Posted by alanpaladka View Post
    no thats the id of the tatasky box the box id of star tv receivers are a bit different look at the screeny below thats a box id of a star tv decoder
