Results 1 to 15 of 15
    Nov 2006
    Default Were is the problem...!
    Jun 2007
    Quote Originally Posted by member91040 View Post
    Bro What happened to ur receiver is it Nokia? or DM.
    Nov 2006
    Dosent know were is the prob bro, Just showing LNB OVERLOAD, I have cheked out the Power to it, its fine , But were is the problem i dont know.
    Jun 2007
    Which Receiver u r using for this ?
    Nov 2006
    Winersat...!
    Winersat...!
    really its winnersat? hahahaha! its a one of the paychannel decoder.....(RAJ TV) RIGHT? may b i am wrong...any how , here its some solution....plz reply for some questions....
    did u connect the lnb directly? or via loop through? or power divider?
    Nov 2006
    hahaha...! connected through Power Divider bro.
    use the non power pass power divider and reset the box...............now it'll ok!
    Nov 2006
    Thanks Alot for an good opinion.
    its really dangerous to use these kind of splitters. go get a twin-out lnb and protect your receiver's tuner in the end.
    this is not a problem of splitters...its the bug of decoder....! if we isolate the lnb voltage between the two boxes by using single power pass multi out put power dividers, then it'll b ok in this case!
    Nov 2006
    You may right bro, I was thinking of that ONE.
    Chennai, India
    I saw the same like this screenshot which member91040 posted. Day before yesterday on SCV cable network! What a coin.....
    well, if you really insist on using splitters, that choice is yours and yours alone. my only concern is for safety reasons.
    bro,,,can u explain why this type of splitter is a problem?,,,what is the correct /safe way to do this?
    cheers,,,dave
