Thread: dish problem
    Default dish problem
    hi all.
    hope u r ok .
    Well i have a problem , on one of my dishes , i can get almost all the channels of Thaicom-3 but i cannot get 3600 frequency ............
    similarly when i moved that dish to Panamsat-7 , then i could get geo tv and some other channels but i could not get the Ary channels i.e 3863 frequency .
    what can be the problem , or should i change my dish ?
    I have changed the lnb but it did not work
    bye
    Banned Member Expert
    Apr 2005
    Coast of Ionian Sea
    your satellite dish has nothing to do with your problem and if it is, you'll get no other frequencies at all......
    you never mentioned your stb's name and model. why don't you upgrade your receivers'[ software/firmware for starters....
    No GUTS!No GLORY!
    Chennai, India
    Quote Originally Posted by superia4u View Post
    hi all.
    hope u r ok .
    bye
    Not all the tps from a satellite is of equal strength. May be the tps you miss would be weaker. Check whether others near you get those tps with same size dish as you have.
    Jun 2007
    hi all.
    hope u r ok .
    bye
    Brother I am able to receive all the TPs Mentioned and Signal is very strong for me,,,
    What size Antenna you are Using for These Sats...?
    Jul 2006
    thailand
    try twisting your lmb 180 degrees maybe skew is not set
    Lahore
    welcome to the board superia!
    plz check if there is any booster(mobile pole) too closer to your home?if yes ,then you will have to purchase single solution F C Band LNB to overcome the problem.
    Are you getting signlas of Hum TV(3774)at same direction?
    Fte Max 100S
    Humax IRCI-5400z
    thank u all for the answer .
    thanks masood for the welcome .
    i will check whatever u said masood and big pimpin .
    and will tell u later .
    thanks again
    bybe
