    Jun 2007
    Default DM500S time problem
    Although I change the time in my DM500S using
    Setup > System Settings > Time settings > Time correction
    it roll back to the old time again without changing.
    Can anyone give a way to correct this? Is there any other place too to change?
    Mar 2007
    Quote Originally Posted by dimu1234 View Post
    No you have to change the time zone.
    Setup > System Settings > Time settings >Time Zone
    Cheers
    Jun 2007
    Time Zone already changed. But it seems that the box change the time with the transponer time. That means few minutes different than the correct time.
    I want to override this auto time update. because each transponder hase different times. Not by hours but by minutes/seconds
    Pakistan
    Default time zone
    humax
    Dreambox
    relook
    truman
    Jun 2007
    Yes I have already done that. I have changed the time zone to GMT + 5.30
    The problem is this. The transponder time of Intelsat 12 (45 E) for Dialog TV is 2 minutes less than the correct time. So when the corect time 11.00 AM Tansponder time is 10.58 AM. So when I set a timer using the green button, the DM zap to that channel 2 minutes after the program started. (I know I can set the timer mannually so that it zap to the channel @ 10.58 AM, But it's easy to set automatic timers if the box time is correct)
    Jun 2005
    Australia
    Don't know what image you're running dimu but isn't there a setting that changes it to not to take time from sat? That should solve your problem once time is set correct.
    Jun 2007
    I'm using Gemini 4.1
    Although I know the place to change the time (even it's not saved), I don't know the place to set 'not to take the sat time'
