Results 1 to 15 of 29
    Sep 2007
    Pakistan
    Default Post Specailly 4 Cable opertators in English
    Salaam dear cable operators
    now i am writing this post in English specially for RDI Forum readers as maximum people can understand English in this forum plz do ignore my English spellings...
    Now we come to the main point
    Dear cable operators i know all of u people suffers frommany problem and most famous is that card black list "Dish Tv" and there is restrictions on some channels which u cannot open from Dish Tv.Even i have jsut hurd on Tv that Dish Tv is illegal in India to use and start channels from Dish Tv on Cable network.i don't know the price of Dream box and Dish Tv decoder in India but in Pakistan Dish tV decoder is almost of 7500 Rs & Dream box 8500 Rs in Karachi markeet.now u can see a tillte difference in the price...
    When u open a channel from Dish TV it show the logo of Dish TV and after few time card number of Dish Tv through which ur card can be block.But if u use Dream box 500 or Envision 500 model then it will not show the card number as well logo of Dish Tv and Tata Sky also and it will save ur cost of extra cards as if u want to open more and more channels u will need a Dish Tv or Tata Sky Box as well as card for every box...
    By using Dream box u have to put only one card in the master Dream box and share it with other Dream boxes by lan and u can open as much channels as u can afford Dream boxes.and one of my freiend ask me that whether Dream Box can unlock Media Guard 2 security level channels also like Star Plus, Zoom and some channels of Zee Network the answer is yes it can unlock full chanels of Meadia Guard 2 security level on slave decoders and NDS of Tata Sky
    Sep 2007
    Pakistan
    i have another method also for removing Dish Tv logo but this is not a safe method as u can only remove the logo of Dish Tv and not the card number but i am tell it here may be it will help anyone in the forum
    if u simply want to remove Dish Tv logo only and not the card number then use this method
    just skip the frequency of Dish Tv promo channel and i know u are thinking that u cannot delete the frequency then how u can skip it.it is very easy just pull the wire of ur dish tv when its PROMO channel frequency comes which is 12535,V,40700 and then reattach it when u able to skip that frequency when installiation complete then it will show u a warning that some channels are miss.Simply ignore it and save ur channels now which ever channel u want to remove the logo just open that channel in any of the active services which are totaly 5 Cinema Active, kides Active etc if the logo does not remove and the active service open in it normal then open that channel in anyother active service in 2 or 3 servise that channel will be Without of Dish Tv logo
    Note: when u people purchse Dish Tv decoder and it ask for upgrade for the 1st time then cancle the upgrade now u have some benifits like u can add frequency, Delete frequency,Dish Tv logo will automatically never comes and nighther the card number but if it is already upgraded then u can do nothing...
    alanpaladka
    Nice post Hassan. I appreciate your efforts behind this!
    Thanks
    Jun 2007
    Quote Originally Posted by Hassan Syed View Post
    Hassan Salam Bhai,
    MY DishTV Box is Updated with Latest SW and I am Unable to Enter or Delete frequency...
    Is there any way to load old software so that I can Add or delete frequency.....
    Thanks in Advance..
    Regards,BLR
    hahaaa! i know to remove card number(FINGER PRINT) and dish tv logo and opening logo also! and in india dish tv box rate is just 3000 rs only....so, its cheaper than a DM!
    21.95° N 97.06° E
    Dear George , how we can remove the card number of Dish Tv?
    Thanks.
    " 李俊明 Born To Help People "
    Sep 2007
    Pakistan
    Hassan Salam Bhai,
    Thanks in Advance..
    Regards,BLR
    Salaam Brother
    u cannot now upgrade ur receiver with the old software it is only when u got the Dish Tv decoder for the 1st time but u can still skip the frequencies by the method told by me in the above post
    Thanks.
    need universal programmer and some hex editor.......we can edit some part in firmware from the flash dump and re program in flash ic...
    Oct 2007
    bhaisab would you be kind enough to explain in more detail as in what software would be required and all
    21.95° N 97.06° E
    Thx. for ur clarify brother , so I've the flash dump of my Kaon receiver.Can u plz. tell me which part to edit the patch?
    Regards.
    Quote Originally Posted by ashraf_7002 View Post
    firmware of the same box..............
    Regards.
    use the hex editer......and u can do some research with it....how i can explain in text?
    Oct 2007
    does this eliminate the card id for ever? and it will never appear?
    Aug 2007
    Is the Card Number hard coded into stb or read from the card at run time ?
    no, u shouldn't edit the card id section.........
