Results 1 to 15 of 23
Thread: DM500S problem
    Oct 2007
    Exclamation DM500S problem
    I have a DM500S. Since today, when I plug it on, the green bulb on the front panel of the box light but the box not turn on. There's no vdeo signal sent to the TV. I can't even switch it off via remote. (That's why I imagine the box not turning on although the green bulb light.)
    Since it not come to work mode, I can't even connect to it via LAN.
    Help me to make the box working again.
    Thanks
    Oz
    Quote Originally Posted by devaka View Post
    Thanks
    Why don't you ask for a possible replacement?
    Oct 2007
    Since I bought it from Thailand when I was in a visit to there, it's not possible to get a replacement
    amar_1v
    Default Dm500s Prob
    same problem with my box, green bulb is countinuesly on, cant turn it on or off, like box is hanged, i tried to connect with com port and lan to flash but not working, plz help.
    Oct 2007
    Default dreambox problem
    dont panic guys nothing to worry in this just follow what i write
    buy one serial cable(rs 232)cable.connect at back of ur dreambox with pc.now download program dreamup from net run program on pc.follow the instructions.try erasing first ur dreambox image.erase few times and should work then after erasing put new image and then plugoff and on again.should work now.but u will loose all channel info and setings
    Oct 2007
    rajput49 Thanks for your reply.
    Put new image means, since I was using Gemini 4.0 I have to put it back is it? Or is there any other DM500S official image to be put after erasing?
    alanpaladka
    @devaka
    You may try to reload the Gemini image again.
    Oct 2007
    That means Gemini via COM port right?
    Feb 2007
    Negombo, Sri Lanka
    Did you try to switch off the power from the wall and keep for few minutes and restart?
    This worked for me.
    DM 600+80GB DM 7020+160GB+ LED 55"
    Oct 2007
    Yes I unpluged it & kept for few hours. But still the same result.
    Jun 2005
    Australia
    devaka, have you tried starting the box both with the coax cable (LNB in) connected and disconnected?
    Sometimes if there's a faulty LNB or cable you might get this problem. If not do as rajput suggested and falsh a new image.
    canine consultant Expert
    It would be interesting to know where you bought it, and why the dealer won't do the right thing with regard to warrenty, or technicial back-up.
    Or did you perhaps get it given to you for nothing.
    name your supplier on here, and wait for the instant service you will no doubt get..
    regards from OZ bassett
    alanpaladka
    Have u reinstalled the firmware via RS232?
    amar_1v
    Default help
    I tried to connect through rs232 and lan but no result, many times turned power on and off , only showing green bulb on, nothing else, can any1 help me?
    Africa-Kenya-Nbi
    Quote Originally Posted by amar_1v View Post
    have you also followed rajputs idea?
